20 Most Recent KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Questions & Answers
2answers
Kitchenaid Refer Icemake not working
replace the emitter and receiver board. see trouble shooting steps on Jpeg. optics boards - resized-undefined-undefined-0_0.jpeg
6/10/2020 7:38:30 PM • KitchenAid... • Answered on Jun 10, 2020
2answers
Ice maker makes too much ice
In my Kitchen Aid bottom freezer there is a metal arm(?) that I lift up to stop the ice maker from making ice. When I start running low on ice, I push the metal arm(?) back down for it to make ice again. Hope this is the solution for your Kitchen Aid too.
12/18/2019 12:50:42 AM • KitchenAid... • Answered on Dec 18, 2019
3answers
Where is the eject button for a kitchenaid superba water filter?
I went through this same thing! You probably can't find an eject button because there isn't one on the model that you have. It probably isn't turning because it's just stuck and you have to just have confidence that you're not breaking it and force it to the left - all of a sudden, it will "pop" and turn easily.
Here is a great link to show you the different types of Kitchen Aid refrigerator filters - which kind has an eject button and which doesn't:
http://kitchenaid.custhelp.com/app/answers/detail/a_id/149
I also found a great (and short!) video from Kitchen Aid that really helped me see how to do it. Try this one - I thought it was the best:
http://www.kitchenaid.com/content.jsp?sectionId=852
Finally knowing there wasn't an "eject" button saved me many hours of looking, and the tip about using the handles of the plyers worked great.
It is really discouraging to think you can't just screw out a water filter, but it isn't you. The directions are misleading - they don't match what you're seeing, and it doesn't twist out easily - it has to be forced....and THEN it twists out easily.
Hope this helps. It worked for me when I'd completely given up.
Best of luck!
Eileen
12/6/2019 6:38:51 PM • KitchenAid... • Answered on Dec 06, 2019
6answers
3 beeps
We had the same problem. Our fridge was beeping and the lights would not come on. To stop the beeping and turn the lights back on we had to press the OVER TEMPERATURE RESET button. As soon as we did this, the lights came back on and beeping stopped. Hope this helps.
8/7/2019 5:07:27 PM • KitchenAid... • Answered on Aug 07, 2019
11answers
Bad water & ice cube taste
Our refridgerator has terrible tasting ice and water and we have tried everything to fix it. Is there a sure fire way to fix the problem. I would love to use the ice maker and water.
miracow
7/2/2019 1:39:27 AM • KitchenAid... • Answered on Jul 02, 2019
Ice maker water taste like chlorine but tap tastes fine
Put a in-line water filter on the water line if you want. The taste is from the food and items you have in the refrigerator. Clean it out and keep your items in proper storage. Ice collects the smells in the line and the fridge. Change your ice that is sitting in the bin, wask out the bin with water and baking soda. Hope this helps.
9/7/2018 10:55:51 PM • KitchenAid... • Answered on Sep 07, 2018
2answers
I have a model KSBP25INSS00. The divider between
Hello ted, I see that you have replaced the compressor fan motor and you have assured as well that the fan is working correct? In all actuality it is best to put the outside fan source around the rear of the machine to blow directly on the compressor itself. Questions for you how fast is the new compressor fan motor spining does it look like it is working properly or is it spining slowly? If the fan were spining properly then you would look at an issue most likely with the condensor where you would most likely have a clog in the condensor itself. You would have to call for a technician to come to your house and replace the condensor. I will await your reply Thanks
Rick
p.s you could also have a clogged capilary line as well which would also cause this as well where the oil from the compressor is not able to move to cool so instead it just heats up due to a blockage in either the capilary, the condensor, or one of the lines. This usually happens from the compressor fan motor not cooling and the unit running and not being able to cool.
7/17/2018 3:49:09 PM • KitchenAid... • Answered on Jul 17, 2018
KitchenAid model KBLO36FMX01 water inlet valve
I hope I'm leading you in the right direction... try this site...I found the part I believe and there is a install video there... http://www.appliancepartspros.com/whirlpool-valve-solenoid-single-wp2313917-ap6007232.html hope it helps.
2/27/2018 2:17:58 AM • KitchenAid... • Answered on Feb 27, 2018
Delay in water dispenser
If you get us a Model # it would help FIXYA Folks help with some suggestions. Should be Inside the refrigerator, on the left wall. silver sticker. Thanks
2/27/2018 1:23:30 AM • KitchenAid... • Answered on Feb 27, 2018
0answers
I have to replace the 8 hour defrost timer on my kitchen Aid KBRS22KWMS fridge every 2 or 3 years , is there a defect with these timers or is there a problem with my fridge that causes the defrost t
In a few cases, the timer is getting condensation damage from a poorly sealing door, or a missing shield. Commonly you'll see corrosion or stains on the timer when you remove it which would be a tattletale sign. Check for both when it fails next.
1/9/2018 3:44:26 AM • KitchenAid... • Answered on Jan 09, 2018
Contol on light blinking, kitchenaide front loading automatic washer, two years old
Obviously there is an issue, perhaps a safety issue. Suggest don't over-ride anything. Check your owner's manual to see what blinking light indicates.
11/2/2017 8:16:30 PM • KitchenAid... • Answered on Nov 02, 2017
Freezer too cold frosty, and refrigerator section too warm
Sounds like a defrost problem if the evaporator is frozen over. If it's just Ice blocking air transfer on a top freezer model, then it's a blocked defrost drain.
9/11/2017 1:56:49 AM • KitchenAid... • Answered on Sep 11, 2017
What does optim ice button mean
OptimIce Feature The OptimIce feature assists with temporary periods of heavy ice use by increasing ice production. Press the OptimIce feature touch pad to set the freezer to the lowest temperature setting. Press the OptimIce touch pad again to return to the normal freezer set point. NOTE: The OptimIce feature will automatically shut off in approximately 24 hours
8/28/2017 2:35:14 AM • KitchenAid... • Answered on Aug 28, 2017
I have a Miele freezer
Try lubricating the bearings in the motor with a very thin oil like sewing machine oil.
8/8/2017 10:38:57 PM • KitchenAid... • Answered on Aug 08, 2017
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
1,409 questions posted
Top KitchenAid Refrigerators Experts
vince
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • KitchenAid Refrigerators
Most Popular Question
water dispenser liiks
  • Refrigerators
