20 Most Recent IDEAL MCM TESTER GFI CIRCUIT Questions & Answers
0answers
Fixing a hot/grd reverse sit.
1) Copy following links for correct wiring illustrations:http://waterheatertimer.org/images/Outlet-polarity-200.jpghttp://waterheatertimer.org/images/Wire-2-outlets.jpghttp://waterheatertimer.org/Troubleshoot-household-electricity.html2) Add a comment dec 2012, for more help If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
12/13/2012 2:46:54 AM • IDEAL MCM TESTER... • Answered on Dec 13, 2012
How do i correct ground
You have the hot wire going to the silver terminal and the grounded wire (neutral) going to the gold terminal You need to reverse the. Hot (Black or Red wire to Gold terminal and the White wire to the Silver terminal.
12/13/2010 1:06:43 AM • IDEAL MCM TESTER... • Answered on Dec 13, 2010
I''ve gotta small issue with an electrical outlet
GFCI receptacles are polarized and connecting them correctly is critical. The hot wire should be black, blue, red, etc. The neutral should be white or natural gray. The ground should be green (if equipped).
Also, it's common to have other receptacles in a kitchen wired "downstream" of a GFCI so that if the GFCI trips or there is an issue with another non GFCI outlet, you're still protected.
Check all outlets in the kitchen and be sure they are wired correctly and in good shape. Unplug everything while you test. If the GFCI still trips, start looking for loose neutrals or bad ground wiring (or no ground) at the other receptacles since you said you already checked the breaker box.
A coffee maker can be a cuplrit that causes a GFCI to trip since it is a heating device and uses water, which can make them more susceptible to electrical problems. Check the microwave too (if equipped).
1/2/2010 5:57:41 AM • IDEAL MCM TESTER... • Answered on Jan 02, 2010
2answers
Electrical issue
Depending on how old your townhouse is, code should dictate that all "wet areas", be GFI protected. In most cases the GFI will not be in the box, but somewhere on the circuit, an outlet that has a GFI reset. You know that the main and master baths are on that circuit, check those outlets for the reset. If none have it, there is likely another outlet somewhere that does. Sometimes one will be in a crawl space or outside. Do you have any outlets out back? In an attic? A utility room? Good Luck! I hope you find this to be very helpful!
12/15/2009 8:31:48 PM • IDEAL MCM TESTER... • Answered on Dec 15, 2009
I need to replace a circuit breaker in my panel.
Yes, but for gods sake be sure to turn off the Main Power switch.
5/28/2009 3:12:30 AM • IDEAL MCM TESTER... • Answered on May 28, 2009
Testing 110 household outlets with 3 light tester,
means hot on neutral.
meaning the black wire or the aluminum screw i shot.
4/1/2009 8:09:46 PM • IDEAL MCM TESTER... • Answered on Apr 01, 2009
Understanding Outlet Circuit Test Results
open ground=ground wire (green) is not connected to the circuit box ground or to the earth ground.
(there should have steel rod place in the ground by the local electric company, and gtound wire is connected to that rod).
Open Neutral= same as open ground. unless you are testing 240V, which have 2 hot (110v) and a neutral (0V).
Open Hot= open 110v line (black)
hot/ground reversed= if you understand the above, then this sould be self explaintory.
same a hot/neu. reverse.
if you don't understand how electric wiring works, My suggestion is to stay out.
2/9/2009 9:31:19 PM • IDEAL MCM TESTER... • Answered on Feb 09, 2009
Will a #61-534 ideal circuit identifier find 480v
no it will not.
4/8/2022 3:04:56 PM • IDEAL Electrical... • Answered on Apr 08, 2022
Testing household outlets with 3 light tester
Have you tried to determine if the problem outlets might be controlled by a wall-switch? This could be the case if separate black wires coming into the box are being used for the different outlets.
12/4/2012 10:01:39 PM • IDEAL Electrical... • Answered on Dec 04, 2012
Manual for scorpion sl2800 generator
Yes
4/9/2024 2:32:16 AM • Electrical... • Answered on Apr 09, 2024
2answers
My conlog meter is showing the rfcon error please what do I do
No connecting to your utilty company in South Africa. Just FYI, we are a North American site and my not always have the answer, in this case we do Https://www.facebook.com/ConlogSolutions/posts/im-having-a-rf-con-error-cant-do-anything-on-the-gadget-please-help-on-how-to-re/962048393965724/ Quoting from link above: "Conlog Hi Ola-daniels, Please see below steps to assist with RFCON error : * Press the Back arrow on the keypad - this step is to refresh the UIU ( the device) * Type # 75 # - this is to check the signal strength If it does not go back to the normal display *Type # 80 # - this is to refresh the meter Then lastly you can repair the meter and the UIU by # 36 # The above steps will work better if you are outside the house because the meters uses the radio frequency connection The above error will occur in instances of bad weather conditions or if there is load shedding or power failure If the problem persists after trying the above you may contact the municipality or the service provider."
SOLVED: How do I clear up the rf con error on my meter ...
https://www.fixya.com > ... > The
May 7, 2020 - How do I clear up the rf con error on my meter because I want to ... Https://www.facebook.com/ConlogSolutions/posts/im-having-a-rf-con-error- ... Hi Ola-daniels, Please see below steps to assist with RFCON error : ... shut down the energy alimentation for 2 minute ,but if the defect persist error it show again. SOLVED: Pole meter conlog rf con meter keep on freezing ... Jan. 10, 2017 Meter reading shows rF CON instead of units available - Fixya Jun. 24, 2018 SOLVED: Good day my conlog ip54 elecricity meter showd ... Oct. 6, 2018 SOLVED: Rf con error - Fixya Jun. 20, 2020 More results from www.fixya.com
Please Help With My Conlog Prepaid Meter - Technology ...
https://www.nairaland.com > please-conlog-prepaid-meter
Aug. 6, 2020 - ystar: If the conlog meter is showing rf-Con, it means power supply doesn't reach the meter at all its either Loss of phase from the transformer or a loose contact ... How Do I Load The Activation Token On My Conlog Prepaid ... Mar. 17, 2020 I Need A Technician To Fix This... - Nairaland / General - Nigeria Jul. 22, 2019 I Need Number Codes To Reset Memmcol Prepaid Meter ... Jan. 11, 2019 More results from www.nairaland.com
3/24/2024 3:42:46 AM • Electrical... • Answered on Mar 24, 2024
Wiring 3 lights 3 separate switches
Consult a qualified electrician.
3/23/2024 7:13:23 AM • Electrical... • Answered on Mar 23, 2024
Kawasaki GA1400A Generator. It starts fine, 12 volts okay, but no 230 volts.
Question edited for clarity. Question moved from Motorcycles to Generators category. Some help in the link, but not as much as I would like https://www.google.com/search?q=Kawasaki+GA1400A+no+230+volts+output ..
2/11/2024 5:52:06 AM • Electrical... • Answered on Feb 11, 2024
GE outdoor 200A fusible disconnect can not stay on position, how to fix this issue
It has a cantilever snap action. Either the spring has detached, broken, disabled or unit is otherwise damaged. Heat, water, rodent, etc damage. Replacing the unit is most likely your only option.
2/9/2024 12:37:45 PM • Electrical... • Answered on Feb 09, 2024
What are the valve specs for a kubota av3800 generator
I want PDF AV 3800 Generator
2/8/2024 2:59:27 AM • Electrical... • Answered on Feb 08, 2024
IDEAL MCM TESTER GFI CIRCUIT Logo
15 questions posted
Top IDEAL Electrical Supplies Experts
Sean Wright
Sean Wright
john h
Are you an IDEAL Electrical Supply Expert? Answer questions, earn points and help others
View Most Popular
  • IDEAL Electrical Supplies
Most Popular Question
correct ground
  • Electrical Supplies
