20 Most Recent Intermatic T104 24h 208-277v Mechanical Time Switch Questions & Answers
Where I can buy the motor of a 24 hour dial time
I had an old Intermatic TN111 indoor timer with the red & green trippers laying around. I just drilled out the plastic plugs holding it together and popped out the timer motor. The timer motor is mechanically identical to the Malibu pool/lighting timer whose timer motor died.. As a bonus you get a spare load switch in case that ever fails.This works for 125VAC timers but not for 230VAC though if you have access to split phase you can run the motor off of 120 VAC and the load off of the 240 VAC
3/9/2023 9:54:13 PM • Intermatic T104... • Answered on Mar 09, 2023
2answers
I replaced my pool clock ( Intermatic)twice. still
I have the same problem with the t104 clock. wired exactly to the diagram. this is the second one, the first one i thought it was a defective timer so i replaced it with another t104 and also wired it exactly to the diagram and still nothing. am i not doing something right???? line 1 to 1, line 2 to 3.....
8/19/2017 7:18:38 PM • Intermatic T104... • Answered on Aug 19, 2017
How to wire intermatic t104 for 120v line and load
it won't work, it would if you had the guts from a 120 volt timer to put in, thats just not practical cuz you would have to get the right timer and at that time you might as well just replace the one your trying to rig up
7/6/2017 1:24:27 AM • Intermatic T104... • Answered on Jul 06, 2017
T104 timer that has a 220volt clock
i would just replace the timer but you have that voltage for what its controlling you get the for that voltage
3/3/2017 1:05:12 PM • Intermatic T104... • Answered on Mar 03, 2017
My t1004r timer does not
If manual override works, then timer is basically sound.
1) If dial does not rotate, then replace clock motor: T104 timer uses 240Volt clock motor. T101 and T103 use 125Volt clock motor
2) If dial rotates, but trippers are missing or trippers are worn down and no longer click on-off lever, then buy new trippers.
T100 series trippers and clocks are shown following link:
http://www.grainger.com/Grainger/timer-accessories/timers/electrical/ecatalog/N-8hi
3) If you have different timer than T101-103-104, then add a comment.
4) Clock motors are located on back of mechanism.
Mechanism snaps out with thumb spring located top inside box.
Clocks have identifying numbers: google search for that clock number if different that shown above.
5) If you buy new timer, then specify T104R.
R suffix is for raintight box.
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html
6) Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on timer or any do-it-yourself project.
9/20/2016 2:53:38 PM • Intermatic T104... • Answered on Sep 20, 2016
Installing lights where natural &hot wires go?
Is this about 120 volt T101 timer? http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#T101 Gene Water Heater Timers Save Money If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
7/19/2015 5:43:22 PM • Intermatic T104... • Answered on Jul 19, 2015
How Do I Set an Intermatic Pool Timer
to set the time on it u rotate the dial use all if ur talking bout the off and on for the load use the trippers
6/12/2014 2:33:49 PM • Intermatic T104... • Answered on Jun 12, 2014
Clock does not work but load does
really need more info. but assuming that ur turn it by hand to turn it on and off, it sounds as tho u have no power on the clock or the clock is bad. is it new? is it old and the clock quit, or new and the clock doesn't work? in this case may not have power to clock.
6/12/2014 2:27:37 PM • Intermatic T104... • Answered on Jun 12, 2014
How to tell differance between 110 volts and 220 volts
u have to use a volt meter to find out for sure. if ur asking how to check it, u find the leads coming into it and take ur volt meter leads and if u have colored wires coming into it like black, red, white, green or bare which is ground. u check the volts by checking the volts 1st on ea of the colors. u should have 120 volts from ea color to ground, then u check volts between the colors. put ur leads to the red, black at the same time and u should have 240 volts. the colors may be black, white, and bare or ground. in this case treat the blk, and white as black and red.
6/12/2014 2:16:56 PM • Intermatic T104... • Answered on Jun 12, 2014
0answers
Dimmer switch buzzing and lights won't stay lit
Check the rating of the dimmer switch. It is more than likely a 600-watt dimmer. Either way you should replace the dimmer switch with a 1000-watt rated dimmer switch.
1/2/2014 7:40:24 PM • Intermatic T104... • Answered on Jan 02, 2014
Need manual for T104R
Copy following link for T104 product manual and wiringhttp://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.htmlGeneh If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
10/10/2013 1:00:42 AM • Intermatic T104... • Answered on Oct 10, 2013
Proper wiring for 220 volts
You posted under T104 timer.
Open following links for wiring information and diagrams.
http://waterheatertimer.org/B220C.html
You say 220Volts and I use 240Volts = same thing
T104 is 240Volt timer with 240V WG1573 clock motor
240Volt cable has two hot wires that arrive from breaker box. These wires connect to terminals 1 and 3.
240Volt cable going to Load has two wires. These wires connect to terminals 2 and 4.
Bare ground wire connects to green screw.
If your timer has terminal A, then terminal A is not used unless you are converting timer for 277Volt operation, or some other specific wiring purpose, or if your 240Volt cable from breaker box also has a Neutral wire, in which case the Neutral connects to terminal A.
If you have different brand timer, or different model number, then add a comment with model number that shows inside timer door, and I will search for wiring diagram.
http://waterheatertimer.org/Boxtype.html
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
5/8/2013 10:29:28 AM • Intermatic T104... • Answered on May 08, 2013
T104 intermatic was replaced but will not turn on
Your wiring is incorrect -or- wire is not under the screw plate correctly -or- the 240Volt breaker is tripped on one leg.Make sure that copper wire is under screw plate, and that no insulation is under plate keeping wire from making contact.Open following link to double-check wiring:http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
2/13/2013 9:53:20 PM • Intermatic T104... • Answered on Feb 13, 2013
Timer Dial d note rotate Pumpm is operational Manually. Any Solution
1) Buy another clock motor:http://waterheatertimer.org/Intermatic-trippers-and-parts.html#T100http://waterheatertimer.org/How-to-troubleshoot-Intermatic-timer.html2) Add a comment and include model number of timer. If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
2/13/2013 7:50:25 AM • Intermatic T104... • Answered on Feb 13, 2013
Intermatic T104 24h 208-277v Mechanical Time Switch Logo
Popular Tags
131 questions posted
Top Intermatic Electrical Supplies Experts
Jay Finke
Jay Finke
ZJ Limited
ZJ Limited
Sean Wright
Sean Wright
Are you an Intermatic Electrical Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Intermatic Electrical Supplies
Most Popular Question
intermatic t104 timer manual switch
  • Electrical Supplies
