20 Most Recent
Rival 38501 Smart Pot 5-Quart Questions & Answers
Can't go straight to warm setting
Hi, Guys,
I discovered this solution by accident. To get my crock pot to go to the "Warm" setting directly, I begin by pressing and holding the "Cook Time" button. Then, with the cook time button held down, press and release the "Off" button, holding it down for a second or so and then releasing it. Finally, lift your finger off the "Cook Time" button. Presto! The unit will be set on "Warm." So the key to this is to press and release the "Off" button WHILE the "Cook Time" button is being held down. Might take a couple tries before you get it, but then you'll see that it works every time.
Need a new cover
Believe or not, go to your local Goodwill Store! They have tons of crocks and the lids and the cookers separate frm each other that have been donated becase one of the pieces was broken and they donated the rest of the pieces. Lids and crocks typically range from $1.99 to $5.99 and you benefit your community at the same time.
My crockpot burns food, even
Your crockpot heat unit is overheating. Return it to the store you purchased it at or contact the manufacturer. My Rival did that and I contacted the company and they sent me a new one.
How many pounds of sloppy joes can I fit in my
Well, that all depends on how dense a sloppy joe mixture you make. If you add pounds and pounds of ground beef to the mix and just the sloppy joe sauce, then it would be many pounds.
But as for a good rule of thumb, "A pints a pound the world around" In other words, if you're making sloppy joes from the pre-mixed cans, just weigh one 16 oz (1 pint) can and that's 1/2 quart.
If you're making it yourself, we're back to the whole density of your chosen ingredents.
However, I've done a little research for you and based on the density of cooked beef and converting the weight of that cooked beef into the 5 quart volume of your crockpot, I've come up with the following info for you.
Cooked Beef has a density 129.52 Ounces per Gallon (a technical measurement)
So based on that data (not including your sloppy joe seasoning/sauce and other add-ins), you should get approximately 10.12 Pounds of Sloppy Joe Mixture to fit into your 5 Quart Crockpot.
I would guess that the amount would be just slightly less, since you might want a little room for putting on the lid, etc., but you should get around 10 Pounds to fit easily in your 5 quart crockpot.
I hope you find this Very Helpful and best regards!
Our 38501 5 quart crock pot liner just busted!
I have a crock pot and the crock broke it was the one with the Ivy on it and had the green oval crock I'm not
sure if it is a 5 or 5.5 qt. I need to replace the crock how much would a new crock cost?
My name is Carol Howard my address is604 Sheridan St.Chenoa,Illinois 61726,my email is
[email protected] please email me back and let me know where and how much it would cost to buy a new crock.Thank you Carol Howard I wait to receive your email
