20 Most Recent Rival 38601 Smart Pot 6-Quart Questions & Answers
2answers
How can I switch my rival programmable crockpot to
A crock pot is an ALL DAY cooking methodology and should not be altered. Fire and personal injury are possible results.
11/3/2021 10:46:43 PM • Rival 38601... • Answered on Nov 03, 2021
Overcooks
The older crocks did not seem to get as hot as the ones form the past 10 years. I have an old blue and white one that I use only to make yogurt, since it is not as hot. I do not believe you can adjust the newer ones, just use the low setting. Good luck.
6/26/2017 8:32:50 PM • Rival 38601... • Answered on Jun 26, 2017
My crock pot has a terrible odor
This crock pot is too old to use anymore and may be dangerous to plug in to an electrical plug. If I were you I would get a new one that has a removable insert that can be cleaned easily. That would be a safe thing to buy yourself. I have one they work great.
6/6/2017 7:01:54 PM • Rival 38601... • Answered on Jun 06, 2017
PLASTIC COVER FOR MY CROCK POT IS CLOUDY
scrub with tooth paste
2/19/2017 2:14:08 AM • Rival 38601... • Answered on Feb 19, 2017
2answers
Green light is blinking, but I am unable to trun the power on.
rival smart pot 38651 crock pot all light blinking
to reset this you need to hold both thye right and left button for 30 seconds. the cause of this is from unpluging the unit when it is on also a power failure will cause this. if this does not work hold all four buttons in. they only tell you this if you get the right person at Jarden Consumer Solutions
www.crock-pot.com
2/13/2017 10:44:54 AM • Rival 38601... • Answered on Feb 13, 2017
7answers
Replacement liner for rival 3860
http://www.crockpot.com/customerservice.aspx?custserviceid=0# click on replacement parts and it is the 6th item. if you need the user manual, follow the link below; http://www.crockpot.com/manuals/38601-C_English.pdf Hope this helps :)
11/18/2016 7:04:15 PM • Rival 38601... • Answered on Nov 18, 2016
2answers
Need a lid
After being asked to call a number of different phone numbers, I was finally able to order a lid for this from the company that manufacturers this slow cooker for Sears.
1-800-361-4639
$25.90, shipped to the US (the company is located in Canada) for the lid.
The part # is: 1003kj.
Note that the Sears model number for the slow cooker is KKC275.
The Sears item # is 68332 (even though the plate on the cooker and manual both say that the MODEL number is 68332).
Hope this helps,
Brian
5/24/2016 3:32:57 PM • Rival 38601... • Answered on May 24, 2016
3answers
Need a Replacement Lid for Rival's Oval Smart Pot Crockpot
I found something on amazon,click here and take a look: Amazon com rival replacement lid. I hope this was helpful. Cheers
12/27/2014 5:15:41 AM • Rival 38601... • Answered on Dec 27, 2014
2answers
The ceramic insert pot from my RIVAL crockpot has broken
Sure there is, take a look on amazon. here: HOOK UP Connect Customize Entertain I hope this was helpful. cheers
12/3/2014 9:08:43 PM • Rival 38601... • Answered on Dec 03, 2014
35answers
Need plastic handle on Rival Crockpot lid.
On amazon you can find every single type of Rival Crockpot lid handles. take a look here HOOK UP Connect Customize Entertain and chose yours (which one fits). cheers
11/22/2014 3:20:08 AM • Rival 38601... • Answered on Nov 22, 2014
Just been given crock pot with 3 settings can you
It sure would help us to help you if you could get the model number off of the bottom of the unit. I can probably locate a user's manual with that information. Try this site to locate the manual: (my best guess without a model number)
http://safemanuals.com/314159.php?k=84c8d7db0922eceeab89e8e236b92e45&ID=2854106&q=CROCK%20POT%20SMART%20POT
(209k)
Find the little blue print that says enter security code and then you can dounload the manual.
The settings should be OFF High 4 High 6, Low 8 Low 10 and warm.
1. Place food in stoneware according to recipe.
2. Plug in Smart-Pot™ slow cooker. The Power light will begin to flash
indicating that the unit is plugged in, but not turned on.
HOW TO PROGRAM YOUR SMART-POT™ (CONT.)
3. Push the Cook Time button to scroll through the timed cooking
options. Push once and the 4 hour light will illuminate, twice and the
6 hour light will come on, etc. Select the time based on the length of
time indicated in the recipe. Two time options are usually given. The 4
and 6 hour settings are the HIGH temperature setting and may be
used when you want your food done quicker. The 8 and 10 hour
settings correspond to the LOW temperature setting and is used for all
day cooking. In addition your Smart-Pot™ can be set to the Warm
Setting by scrolling through the timed cooking options until the warm
light illuminates.
NOTE: The Warm setting is for keeping already hot food warm. Do not use
the warm setting to cook or reheat food.
4. When the cooking time is completed, the Smart-Pot™ slow cooker will
automatically shift to the Warm setting and the Warm light will come
on. NOTE: We do not recommend using the Warm setting for more
than 4 hours.
5. To turn the Smart-Pot™ off push the OFF button. Unplug unit from the
wall outlet.
6. For other recipes that give a range of times, select the time closest
to the setting on your Smart-Pot™. For instance a recipe calling for
cooking time of 7 to 9 hours on LOW, set your Smart-Pot™ to 8 hours.
NOTE: If power goes off then power light will blink and settings must be
reset. If cook time is changed before the cycle is complete the time will
reset to the new setting.
Thanks for choosing FixYa,
Kelly
11/12/2014 2:33:55 AM • Rival 38601... • Answered on Nov 12, 2014
5answers
Replacement cover for Rival 38601 Crock Pot
No, dont throw it away!!! You can use tin foil as a lid - I do this all the time as my lid shattered too and it works perfectly. You dont have to adjust times or anything.
5/16/2014 4:59:33 PM • Rival 38601... • Answered on May 16, 2014
406 questions posted
Top Rival Crock Pots & Slow Cookers Experts
Paul Carew
Paul Bade
Are you a Rival Crock Pot and Slow Cooker Expert? Answer questions, earn points and help others
View Most Popular
  • Rival Crock Pots & Slow Cookers
Most Popular Question
need lid
  • Crock Pots & Slow Cookers
