042568 2 SCREW HHC M6-1.0. X 20
2 0G8588 1 CONTROL PANEL BOX
3 049811 2 WASHER, FLAT M6
4 022097 2 WASHER, LOCK M6
5 049813 2 NUT HEX M6 YELLOW CHROME
6 0G9537 1 GASKET, CONTROL PANEL
7 0G9551 1 WIRE HARNESS (8KW)
(NOT SHOWN)
0G9709 1 WIRE HARNESS (6.5KW)
(NOT SHOWN)
8 0E6480 14 NUT HEX LOCK M4-0.7 NYLON INSERT
9 043180 14 WASHER, FLAT M4
10 0D4966 2 OUTLET, 20A GFCI DUPLEX BLACK
11 0H0265C 2 CIRCUIT BREAKER 20X1
12 0G8586A 1 CONTROL PANEL
13 0G9070 1 OVERLAY, CONTROL PANEL
14 0C7341 2 BOOT/NUT, PUSH BUTTON SWITCH
15 0G9392 2 COVER, 20A 120V GFCI DUPLEX
16 025105 4 SCREW RHMS 6-32 X 1/4
17 0G9391 1 COVER 30A 120/240 OUTLET
18 0G8321 1 HOUR METER
19 0G9393 1 COVER, 12V DC JACK OUTLET
20 0G5699 1 12VDC POWER JACK
21 0G8758 1 RECEPTACLE 30A
22 0C7340 1 BOOT, CIRCUIT BREAKER
23 0G9023C 1 30A CIRCUIT BREAKER (8KW)
0G9023E 1 27A CIRCUIT BREAKER (6.5KW)
24 0F5458 2 SCREW PLASTITE HI-LOW #10 X 3/8
25 042632 1 GROMMET 1/2 X 1/16 X 3/8
^-Note: There is no fuse listed
The only fuse I am aware of is an in-line 1.5A slow blow^ fuse for the Battery charging circuit
The starter is item 8 of the engine manual page 4
The starter solenoid is itme 91 of the manual OG9666
91 086729 1 STARTER CONTACTOR
What problem are you having and I can probably help you?
Thanks for choosing FixYa,
Kellly
31 questions posted
