The camera is warning you that the shutter speed may be too slow for you to handhold the camera steady enough to prevent camera motion from blurring your photo. For full details refer to the "Warning Messages and Displays" section of the manual (page 113 in my copy). If you need a manual you may download a copy here.
Zooming is addition important application with digital cameras - there are two kinds of zoom: optical zoom and digital zoom. An optical zoom agency is one that relies on the lens itself accumulative the ablaze advancing in, so that what is abroad appears beyond and afterpiece in the consistent image. An digital zoom agency is one that takes the consistent angel and magnifies it afterwards the fact. Needless to say, an optical zoom agency is abundant added important than a digital zoom.
Digital zoom enlarges the ccd image and will become more pixelated the more you zoom and optical zoom uses an actual lens to magnify the image coming into the camera. optical zoom is better than digital zoom.
How about turn the nobe on the top. It is on the movie part. so it is recording movie. Change it to P or some other letter. You should be able to take picture now. good luck
Auto Mode
In this mode, all you have to do is press the shutter button and let the camera do everything else.
1. Turn the camera on.
2. Turn the shooting mode dial to .
3. Aim the camera at the subject.
4. Use the zoom lever to achieve the desired composition (relative subject size in the viewfinder).
The angle of view can be adjusted within the 45 to 100 mm range, in 35mm film equivalent.
When the LCD monitor is on, the combined use of the digital zoom and optical zoom enables magnified shooting up to approx. 7x.
5. Press the shutter button halfway.
Two
beeps will sound when the camera has finished metering, and the
indicator will light green or orange. If the LCD monitor is on, the AF
frame will appear green.
The yellow indicator will blink and the beep will sound one time if the subject is difficult to focus on.
6. Press the shutter button all the way.
You will hear the sound of the shutter when the shutter activates.
The picture appears for two seconds on the LCD monitor, if it is on.
The indicator next to the viewfinder blinks green while data is recorded onto the SD card.
The D-630 has a 3x optical zoom and a 4x seamless digital zoom. In order to use the digital zoom, press the OK/MENU button on the back of the camera. Press the right arrow key to access the Mode Menu. The first setting under the CAMERA tab is DIGITAL ZOOM. Press the right arrow key to highlight this setting and then press again to select ON. Press the OK/MENU button to set the DIGITAL ZOOM to remain ON. When you press the zoom button with the T on it, a zoom indicator will display on the right side of the LCD. The W represents a wider area of view as you zoom out, and the T represents telephoto as you zoom closer to the subject. When the zoom indicator is in the red zone, you are using the digital portion of the zoom. images taken in the digital zoom will appear “noisy” or “grainy” which is normal when using the DIGITAL ZOOM.
The D-595 Zoom camera has a 3x optical zoom coupled with a 4x “seamless” digital zoom to deliver a total 12x zooming feature. Press the Zoom button and a zoom indicator will be displayed in the upper right corner of the LCD – the area in white represents the Optical Zoom range and the red area represents the range of the Digital Zoom. The W represents a wider area of view as you zoom out, and the T represents Telephoto as you are zooming in closer to the subject.
The D-545 Zoom camera has a 3x optical zoom coupled with a 4x “seamless” digital zoom to deliver a total 12x zooming feature. Press the Zoom button and a zoom indicator will be displayed in the upper right corner of the LCD – the area in white represents the Optical Zoom range and the red area represents the range of the Digital Zoom. The W represents a wider area of view as you zoom out, and the T represents Telephoto as you are zooming in closer to the subject.
The D-535 Zoom camera has a 4x digital zoom in addition to the 3x optical zoom, which gives you a total of 12x zoom overall. Press the Zoom button and a zoom indicator will be displayed in the upper right corner of the LCD – the area in white represents the Optical Zoom range and the red area represents the range of the Digital Zoom. The W represents a wider area of view as you zoom out, and the T represents Telephoto as you are zooming in closer to the subject.
