Recognition of cartridges depends on several issues. Check and clean the metal contact points on the printer cartridge slot. Use rubbing alcohol on a q-tip and pat dry. Do the same on the ink cart. Any oil/film on the contacts can interfere with the communication network of the printer. Sometimes, printers just reject cartridges, mainly if you use off brand products. Naturally HP wants you to use their cartridges! Other than that, you must use HP Software updates for the computer and also, update each HP Printers FIRMWARE. Lots of folks forget that!
SOURCE: lexmark x1180 printer all in one
Clean the contacts on the cartidge and printer ( open the replace ink door wait for the printhead to come to center and turn off power) if that does not work then replace cartridge, it might be a recycled one that they did not chane the chip.
SOURCE: Tri Colour cartridge inserted is not intended for use in this printer msg
Try to clean the print cartridge contact points with a good rubber eraser and clean the printer side cartridge contacts with good lint free cotton cloth. Then first insert Black cartridge and then colour cartridge. Use some more pressure while attaching the cartridges.
SOURCE: I just purchased an HP
Hi
If the printer is out of the Box, don not try any other ink cartridges, becoz you must use the HOST ink cartridges that is shipped with the printer for the first time.It seems that it is problem with Host ink cartridge.
You can check the cartridge whether its a Host ink cartridge or normal one by looking at the serial number.If Serial number starts with C9, it Host; if it starts with C8 its normal one.
Only HP can replace it , none of the store sells Host ink cartridges, they sell the replacement ones.
You can either call HP tech support or, return the printer to staples.
Thank You
Rizwan
[email protected]
SOURCE: Printer says Remove and check colour cartridge
hi john
see if any on there site helps yo here theres also a manual on here as well.
Ink cartridge or toner, paper & accessories HP Photosmart C4183 All-in-One Printer
riz.
SOURCE: Ink cartridge cannot be recognised
Take the cartridges out and clean the electricial contacts with a pencil eraser, the reinstall them.
