Casio Parts Cash Register PC Desktop Logo
Anonymous Posted on Jul 24, 2011
The "00" key does not
  • Anonymous Jul 24, 2011
    Not sure how to do this. There is nothing in the manual to change the decimal point :(
Anonymous
Level 2:
New Friend:
  • Expert 112 Answers
  • Posted on Jul 24, 2011
Anonymous
Expert
Level 2:
New Friend:
Answers
112
Questions
Helped
23997
Points
345
Is the a decimal point selector?....If so it is set 1 decimal off
  • 3 more comments
    whats the model number?
    PCR T-2000
    interesting.....try this....hit 4 and the single zero 2 times....or 4 and dont hit zero at all
    THANKS. THAT IS WHAT I HAVE BEEN DOING. OH WELL...NO BIGGEE..JUST WONDERED WHY IT STOPPED WORKING. THANKS FOR YOUR TIME.
    I think it might be programmed and need to be reset because reading the manual you should be hitting 4 and the double 00 key and get 4.00
"Web" no gateway reply
Try this: 1) Open the phone's Settings ---> Connection ---> Wireless LAN ---> Hit the options button (left soft key) and select 'Advanced Settings'.
2) When this appears: " Changing the advance settings is not recommended. Continue Anyway?" Select Yes to enter the Advanced Settings screen.
3) Click 'Automatic configuration' to set it to Disabled.
4) Scroll down to the 'Power saving' option in the menu and set it to Disabled.
You should be able to to browse Internet on N95.
If still you can't connect to the Internet, try this:
Check WEP Key. Maybe you entered in incorrectly.
If you entered the correct WEP key and it won't work, you need to change the WEP encryption key from the 13 alphanumeric combination that the router came with by default to a string of 26 Hexadecimal (Hex) characters (0-9 and A-F).
tip
Toshiba Laptop BIOS Password Removal
<span><b>ESC Key BIOS Password removing procedure</b><br />1. Starting with the computer fully off, turn it on by pressing and releasing the power button. Immediately and repeatedly tap the Esc key. The computer will display the "Password = " prompt.<br />2. Enter the correct password, and press the Enter key. The computer will display "Valid password entered, system is now starting up. Check system. Then press (F1) key"<br />3. Press the F1 key. The BIOS setup program will appear.<br />4. Using the arrow keys or the tab key, move to the password field, and highlight REGISTERED.<br />5. Press the spacebar, enter the correct password, and press the Enter key. The Password field will change to NOT REGISTERED.<br /><b><br />F2 Key BIOS Password removing procedure</b><br />1. Starting with the computer fully off, turn it on by pressing and releasing the power button. Immediately and repeatedly tap the F2 key. The unit will display the "Password = " prompt.<br />2. Enter the correct password, press the Enter key. (You may need to press the F2 key after you hit the enter key.)<br />3. The BIOS setup program will appear.<br />4. Using the arrow keys, move to the Security tab, and to Set User Password.<br />5. Press the F5 or the F6 key to navigate to the Password section. Enter the current password at the Old Password prompt, and press Enter. At the New Password prompt, press Enter (without typing anything into the password field). At the Confirm Password prompt, press Enter again (without typing anything into the password field). The password should now be removed.<br />6. Press F10 to save and exit from the BIOS Setup program.<br /><br />In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.<br /><br />If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.</span>
on Jun 09, 2011 • Computers & Internet
tip
Avaya Partner Phone System Programming
Programming Without Button Overlays: <br />Although it is advisable to have a Partner programming manual and overlays when performing changes. Here are the basic steps for changing system time, day and date. The "Feature" key is self explanatory while other keys need a reference. "System Program" key is the left intercom key on the phone. The "Central Tel" key is the right intercom key. The "Next Data" key is the third key from the left with an LED on the top row of an 18 Button display set. Numbers # and * are simply entered as numbers of the dial pad.<br /><br />Avaya Partner System Date Program #101<br /> <br />Use this program to set the month, day and year. The system displays only the month and day on display telephones when the telephone is idle: the month, day and year also print out on SMDR call reports when used.<br /><br />Considerations: <br />The System Date date-stamps the back up files when you use Backup Programming.<br /><br />Programming Without Button Overlays:<br />The "Feature" key is self explanatory while other keys need a reference. "System Program" key is the left intercom key on the phone. The "Central Tel" key is the right intercom key. Numbers are simply entered as numbers of the dial pad.<br /><br />Programming: To change system date: Press Feature, 00, System Program, System Program,#,101 at extension 10 or 11. Enter today's date in the form of "mmddyy" (Month, day, and year), including leading zeros for single digit months or days. For example, to enter April 26 2003, press 042603. A display similar to the following appears: System Date Data 042603. Exit programming mode by pressing Feature, 00 or lifting and hanging up the handset.<br /><br />Avaya Partner System Day Program #102<br />Use this program to set the day of the week that appears on system display telephones.<br />Programming: To change system day: Press Feature, 00, System Program, System Program,#,102 at extension 10 or 11. Change the day by pressing "Next Data" until the day you want appears:<br />1=Sunday<br />2=Monday<br />3=Tuesday<br />4=Wednesday<br />5=Thursday<br />6=Friday<br />Exit programming mode by pressing Feature, 00 or lifting and hanging up the handset.<br /><br />Avaya Partner System Time Program #103<br /> <br />Considerations: <br />Enter the time in 24 hour notation. In this scheme, the hours of the day are 0000 (12 midnight) to 2459 (11:59). Since each time must have four digits, use leading zeros when necessary. The time appears on system phones as A.M. or P.M., not 24 hour notation.<br /><br />Programming: <br />To change system time: Press Feature, 00, System Program, System Program, #,103 at extension 10 or 11. Enter a new time in 24 hour notation. For example, to set time to 2:15 P.M., press 1415. This time will appear on the phone as 2:15 P. Select next procedure or exit programming mode by pressing Feature, 00 or lifting and hanging up the handset.
on May 27, 2011 • Lands Phones
4helpful
3answers
I have older Toshiba laptop A15-S1292 running XP SP3. Problem is every time it start, before anything can be seen, it ask for password. I know the password, but I do not know how to romove the...
How do I delete and add numbers to the speed dial on my Samsung SF340 fax machine
1 Press and hold the Speed button for about two seconds.
• The display shows Speed [00-80]>##.
2 Enter a two-digit (00~80) number and press Enter.
• From 00 to 09 will be used for One-Touch dialing, and from 10 to 80 for Speed dialing.
3 Enter the telephone/fax number you want to store (up to 40 digits) and press Enter.
• If you want a pause between numbers, press Redial/Pause; a 'P' appears in the display.
• If you make a mistake while entering a number, use to move the cursor under the digit, then enter the correct digit.
4 Enter the name and press Enter.
• If you do not want a name, just skip this step by pressing Enter. If you have subscribed to a Caller ID service,
it is recommended you enter a name.
• You can assign up to 20 characters to a name. see "How to enter letters" on page 1.7.
5 Press Stop/Clear to exit.
3helpful
Windows logon.exe error in XP
try thease steps 1. Insert a XP CD (any XP install CD will do for this procedure) and boot up.
2. When asked, boot to the CD by hitting the Enter key.
3. After a short while, a menu will appear.
Select R for repair.
4. Next, you will be asked which Windowsmag-glass_10x10.gif installation to use. Hit the 1 key on your keyboard and then Enter (assuming it is the C drive).
5. You may be asked for an administrator password. At which point you will need to enter it or hit Enter if their is none.
At the resulting C:\Windows> prompt in the recovery console , type 'CD System32' (without the quotes).
6. Next type:
'copy userinit.exe wsaupdater.exe'.
7. Exit and reboot normally. You should now be able to logon. But you're not done yet!
8. Run regedit from the Run line.
9. Find the Userinit key in:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon\
10. Modify the entry:
C:\WINDOWS\System32\wsaupdater.exe
so that it reads:
C:\WINDOWS\System32\userinit.exe
2answers
Starveiw is not setting up
how do you mean not setting up does it say updating code because if it does you need these you can put the codes in by pressing menu then language then press 1968 twice choose your provider then change codes
LATEST KEYS ALL AREAS
EX C&W KEYS -- KEYROLL 04/12/2008
PROVIDER CODE: 5C 01
KEY 00 = D4 A3 5D EB 7B F3 69 59
KEY 01 = 27 77 A1 FC 8F 9D 34 76
TELEWEST KEYS -- KEYROLL 04/12/2008
PROVIDER CODE: 5A 01
KEY 00 = C0 F6 61 87 91 F9 67 57
KEY 01 = F0 83 35 E5 28 40 49 B2
PURE NTL KEYS (UK) -- KEYROLL 04/12/2008
PROVIDER CODE: 54 01
KEY 00 = 3F B8 36 62 72 E5 E2 76
KEY 01 = 35 5E D6 40 6E AA 99 41
IRELAND CHORUS KEYS -- KEYROLL 29/06/2008
PROVIDER CODE: 5E 01
KEY 00 = 51 0F 32 A7 D9 34 BE 3E
KEY 01 = 8D A3 88 1B 4E 32 C5 8F
IRELAND NTL KEYS -- KEYROLL 18/06/2008
KEY 00 = 75 92 B1 CC 6F 23 20 F1
KEY 01 = F2 46 B1 59 04 61 77 71
3answers
Anyone got codes for 4th December??
4.12.08.
ntell
0=3F B8 36 62 72 E5 E2 76
1=35 5E D6 40 6E AA 99 41
tw
0=C0 F6 61 87 91 F9 67 57
1=F0 83 35 E5 28 40 49 B2
Time displayed in window
With the printer turned on, hit the "Setup" button, then use the "Options" button and the right cursor button below it until "Set Fax Functions" appears in the window. Then hit "Enter" and follow the prompts to first enter the date (00-00-00) using the number buttons, then the time (same buttons). Set either a.m. (1) or p.m. (2) using the same buttons.
18helpful
23answers
Virgin codes for starview box
To enter the codes: Press "menu" then enter "1570" and a secret menu appears. **MAKE SURE "EMU" IS SET TO "ON"** Selecet "Nagravision" and the codes will appear. At the top select your provider: N*L, EX C*W, CH*&US etc, then in the box below select key 00. Move down to the keys below. Enter the codes by a combination of the number keys on the remote and "Audio", "Pause", red, green, yellow & blue buttons for the letters A to F.
After you have entered keys for 00 press "OK" to save. Go back up and select Key 01. Move back down and enter the codes for 01 then press OK to save.
Press exit & exit again until you get back to the first MENU screen. Press "Installation", select your provider again, go down the menu and press Auto search. This should then find all programs. After the programs have been found press exit & it should say something like saving or updating data. Then you should be able to view your channels again.
Top Casio Retail Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
Are you a Casio Retail Supply Expert? Answer questions, earn points and help others
