Initial Setup
One adjustment is important before we get started. By default the 12C displays only two decimal places. This is not enough. Personally, I like to see five decimal places, but you may prefer some other number. To change the display, press "F" and then the number of decimal places you wish to display. I would press "F 5 " to display 5 decimal places. That's it, the calculator is ready to go.
Click this link below and follow the procedure:---
http://howtobyme.blogspot.com/2011/07/hp-12c-calculator-help.html
This
should help.Thanks.Helpmech.
Actually that youtube video is not loaded properly.Its showing fine not found.----But what i want to know is, were you getting 2 or more digits before the decimal, when you got this calculator and just now it stopped or , its a new calculator and you are not getting more digits before decimal.---
were you getting more digit to the left of decimal, when you got this calculator.---------
If yes, then did you changed any setting that caused the problem.---------------
Keep updated.Thanks.Helpmech.
hi, the #'s after the decimal point are working just fine, able to switch using f key back and forth to 5 decimal places.
however, not able to enter more than 1 digit BEFORE the decimal place. thanks! Also if I hit enter it takes the display back to 0.
recorded on youtube a video - reset a no go :( thanks!
http://youtu.be/EpiC7-XBSwI youtube link
http://www.youtube.com/watch?v=EpiC7-XBS...
Doesn't work?
it was my boss' old calc using for a test tomorrow.
Never mind - I got another one from him that seems to be ok and we are changing out batteries.
