Sony Cyber-shot DSC-WX1 Digital Camera Logo
Posted on Jul 17, 2011
Error: Turn the power off and on again on the LCD screen
Ravi Yelde
Level 1:
New Friend:
  • Contributor 27 Answers
  • Posted on Jul 17, 2011
Ravi Yelde
Contributor
Level 1:
New Friend:
Answers
27
Questions
0
Helped
7881
Points
76
Please make sure that the Camera is fully charged.
Please check if the Menu items in the Camera are accessible.
If accessible, please try initializing the Camera and check if that helps.
To initialize the Camera :
Please press MENU button of the Camera.
Then, Select the SETTINGS Menu (Briefcase icon).
After that, please select the MAIN SETTINGS (Wrench Hammer symbol).
Now, please select the INITIALIZE option.
Then, select OK.
The Camera will ask for initial settings of date and Time and language.
If the issue is unresolved after performing the above steps, the Camera has to be serviced.
Please contact the Authorized Service Center.
When camera turn , on screen -turn off and on again
Error: TURN THE POWER OFF AND ON AGAIN is displayed on the LCD screen when the Lens Mechanism is stuck or when affected by any malfunction. If turning the power on and off again does not resolve the error message, try doing a power reset and Initialize option.
Performing a manual power reset
Turn off the camera.
Remove the battery pack.
Press and hold the power button for 30 seconds.
Allow the camera to remain without power for 60 seconds.
Reinsert the battery pack.
Turn on the camera.
To reset the Camera back to factory default, select the INITIALIZE Option from the Main Setting Menu of the Camera to OK. This will set the user defined settings back to factory default. The images and videos will not get deleted.
If the issue persists, service may be required.
Thanks for contacting FixYa.
Yes.turn power off and on again on the screen
Turn on the camera.
To reset the Camera back to factory default, select the INITIALIZE Option from the Main Settings 1 Menu of the Camera to OK. This will set the user defined settings back to factory default. The images and videos will not get deleted.
Error message - turn the power off and on again....can't resolve
Turn on the camera.
To reset the Camera back to factory default, select the INITIALIZE Option from the Setup 1 Menu of the Camera to OK. This will set the user defined settings back to factory default. The images and videos will not get deleted.
1helpful
Try to zoom,and a warning comes on the screen to turn off and on again but doesn't work.
Turn on the camera.
To reset the Camera back to factory default, select the INITIALIZE Option from the SET UP1 Menu of the Camera to OK.This will set the user defined settings back to factory default. The images and videos will not get deleted.
Thanks
4helpful
2answers
Turn power off and on again. Shutter won't close.HELP
Turn on the camera.
To reset the Camera back to factory default, select the INITIALIZE Option from the Main Settings Menu of the Camera to OK.This will set the user defined settings back to factory default. The images and videos will not get deleted.
1helpful
?· Turn off the camera.
?· Remove the battery pack.
?· Press and hold the power button for 30 seconds.
?· Allow the camera to remain without power for 60 seconds.
?· Reinsert the battery pack.
?· Turn on the camera.
Thanks,
KenSolutions
FixYa
Error message turn the powe off and on again
Turn on the camera.
Error message when turned on
Turn on the camera.
When I turn my camera on, the screen remains black and says turn power off and on. Upon doing so, when i turn it on again, it begins beeping and says turn power off and on. But if I go to the view pictures...
Turn on the camera.
To reset the Camera back to factory default, press the RESET button located above the PHOTO button which will change all settings back to factory default. The images and videos will not get deleted.
2answers
When I turn my Sony Cybershot 7.2 mega pixel camera on, the lens keeps going in and out and the message "Turn the Power on and off again" shows up on the LCD screen. When I turn the power off and on again,...
Thanks,
KenSolutions
FixYa
Top Sony Cameras Experts
ZJ Limited
ZJ Limited
Are you a Sony Camera Expert? Answer questions, earn points and help others
