My TI-84 Plus Silver Edition stopped working a few days ago. It says the following message: "Waiting Please Install Operating System Now"....
I attempted to reset it, but no luck...
What can i do?
I finally fixed my calculator~
1. if you have a ti 84 plus silver, plus, or just ti 84, find a friend who has either a ti 84 plus silver, plus, or just ti 84. (as long as the number is the same)
2. link the two calculators together
3. using your friends calculator, press the [2nd] and the one next to alpha [x,t,o,n]
4. go all the way down to [send os]
5. send it to the other calculator and your problem should be fixed
Hola amigo me paso lo mismo solo que no tengo otra calculadora tendras una copia de seguridad de tu sistema de calculadora para recuperar el sistema por favor
~Connect the TI Connectivity cable between the PC and the calculator.
~Click on Start >> Programs >> TI Tools >> TI Connect >> TI OSDownloader
~Follow the on-screen directions to reinstall the calculator's OS. When or, if the calculator install the fresh OS goto step 4.
Remove all of the batteries including the round lithium battery for 5 minutes. After the 5 minute period, reinsert all of the batteries and turn the calculator on. Adjust the contrast if necessary.
If the above process did not work. Try re-doing the procedure and, extend the time in step 4 by 5 minutes to 10 minutes before you put all the batteries back in the calculator.
~Connect the TI Connectivity cable between the PC and the calculator if you haven't already.
If the above process did not work to turn your calculator on, try re-doing the above process. Next time extend the time in step 4 by 5 minutes to 10 minutes before you put all the batteries back in the calculator.
The reset procedure will delete all the items that are in the memory of the graphing calculator. Use the reset procedure below:
• Remove 1 AAA battery.
• Press and hold down the [DEL] key.
• While holding down the [DEL] key, replace the AAA battery, and press the [ON] Key.
The message Waiting... Please install calculator software should appear. At this point, it will be necessary to reinstall the calculator's operating system.
• Connect the calculator to the computer using the TI Connectivity Cable or DirectUSB Cable.
Please post if this was helpful...
• In Windows®, click on Start >> Programs >> TI Tools >> TI Connect >> TI OS Downloader.
• In MacOS® X, open Hard Drive >> Applications >> TI Connect >> TI OS Restore.
• Follow the directions on screen to reinstall the calculator's operating system.
Access the link following for detailed instructions on how to complete operating system installation.
i have it to
