After 1700 shots it is recommended that both upper and lower punchers as well as all seals in the brew unit be replaced. These punchers are only plastic so they do get worn down after much use. You may also be experiencing more water in your drawer as water is leaking from around the capsule seal. This is also an indication that the seals and punchers should be replaced. Given where you go to have this fixed, the parts may cost less than $15.00.
