Try to remove float bowl and clean out then spray carb cleaner into the jets
Probably going to have to clean that carb out. Old gas may have gummed up the float valve or something else. If you get it to idle, I have a 4stroke craftsman that would bog with any throttle. Ran a bunch of cheap walmart injector cleaner in the gas and ket it idle for a few minutes. That seemed to clean it up- could run it wide open without issue. That stuff was a little over a dollar, so cheap to try. Just have to at least get it to idle first.
Try some carb. cleaner/ starter fluid on that spark plug right before you try to crank it. If that does it
replace your spark plug.
SOURCE: need to know the spark
The spark plug gap should be set at .025 to .030 inches for trimmers. Try to set gap closer to .025.
