Theencryption key secures your data from unauthorized access. The router's password is a Passphrase or the WEP or WPA orWPA2 encryption key. The Passphrase generates the WEP or WPA or WPA2 encryptionkey and this is in the router's wireless settings. To connect to your wireless router, configure the router'swireless settings ie SSID, plus the WPAor WPA2 encryption key and then configure wireless cards in the laptops and orcomputers with these router's wireless settings. Then the laptops and desktopcomputers can communicate with your wireless router.
Many laptops have a way to enable/disable their wireless connection. Some laptops have a sliding switch on the side. Other laptops use a combination of keys such as Shift F6 to enable/disable the WiFi connection. Most of these switches and/or function keys have an antenna icon printed on them. The first step in connecting your laptop to the wireless router is to make sure your laptop's WiFi is turned on. You should see an icon appear at the bottom of your screen that looks like a computer with radio waves coming in/out of it. Left click on this icon and another window will pop up. Use this window to have the computer search for or view available wireless networks. A list of the available networks should pop up. Click on the name of your network and tell it to connect. It may ask you for a security pass key if you have security enable on your router. Type in your pass key twice and hit connect. You should only have to do this once. The laptop should remember the pass key after that and automatically connect. I hope this advice helps you out.
SOURCE: unable to access linksys wireless router,with
Hello trinijazz,
To accomplish the setup of the router, you need to be using a computer that is connected directly, harwired, into the router itself. If you don't have two computers, use the laptop but connect it into the router using the ethernet port, and ensure that the wireless on the laptop is off.
Open up your browser window and Enter 192.168.1.1 in your browsers address bar, no HTTP or anything, just the numbers, and press enter. A login box will appear that is asking for a User Name and Password. They are both, in lower case: admin then click on Login. This will take you to the Linksys Setup screen.
You have tabs at the top/center of the screen.
1) Click on the Setup tab and verify that in the drop down box it is set to: Auto Configuration-DHCP.Then verify that the time zone at the bottom is set accordingly. Do not make changes to any other settings on this screen.
2) Click on the Wireless tab at the top. Set the Wireless Network Mode to Mixed
Then choose a Network Name. This is the connection that you will connect your laptop to wirelessly.
Set the Wireless Channel to 11-2.462ghz
At Wireless SSID Broadcast click on Enable
DO NOT EXIT THAT SCREEN
3) Directly above the box where you entered MIXED, click on the sub-tab labeled Wireless Security
Security Mode: WPA2 Personal you can use WEP but WPA2 is more secure. If your laptop has connectivity issues with WPA2, try using WEP.
WPA Algorithms: I use TKIP+AES
WPA Shared Key: This is YOUR network key. Write this down and keep it in a safe place or just remember it. You will need this when you try and connect your laptop wirelessly.
Group Key Renewal: should already be set to a default of 3600
Click on the SAVE SETTINGS button
The last thing I do is I go back through each page and if some changes weren't saved I fill in the appropriate information and click the SAVE SETTINGS button for each page. You shouldn't have to but it doesn't hurt.
Last but not least, go to your laptop ( I would recommend restarting it) and turn on the wireless. You should see your newly created network and after choosing to Connect To A Network, enter your Network Key and you should be good to go.
Hope this helps
