Texas Instruments TI-84 Plus Calculator Logo
Posted on Jun 24, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I accidentally press reset all and now all my apps are gone. I was wondering how I can restore it back to normal with all the default apps just like when I bought it. Please explain in step by step fashion on what I should do.
k24674
Level 3:
  • Texas Instru... Master 8,093 Answers
  • Posted on Jun 24, 2011
k24674
Level 3:
Answers
8093
Questions
0
Helped
4674766
Points
21596
Go to education.ti.com . Download all the applications you want from this page and install them on your calculator.
For that you will need a mini to Standard USB cable or a TI USB Silver cable.
The drivers for the cable have to be installed manually if the computer does not recognize the device.
  1. From the TI website (computer software) download TI connect and install it on the computer.
  2. Run TI Connect, and verify that it finds your calculator:
  3. In TI connect main window, click Screen Capture or Device Information, or Device Explorer.
  4. Once the calculator is correctly identified, drag an application downloaded from TI and drop it on the TI Connect main window.
  5. It will install on the calculator.
  6. After transferring two or three apps, stop to allow the calculator to defragment the memory space.
  7. Resume transferring applications.
Casio FR-2650TM. There was a bunch of the #2 all across the screen, wouldn't clear. Power cycled. Now it won't turn on. I've hit the reset button, but nothing.
• Pressing the RESET button on the back of the calculator deletes independent memory contents, tax rate settings, etc. Be sure to keep separate records of all important settings and numeric data to protect against accidental loss. • Press the RESET button to restore normal operation whenever the calculator does not operate correctly. If pressing the RESET button does not restore normal operation, contact your original retailer or nearby dealer.
Hi. what is default password Ip Camera model vivotek ip7730 ?
By default, the Network Camera is not password-protected.
Hardware Reset
The reset button is used to reset the system or restore the factory default settings
Sometimes resetting the system can return the camera to normal operation If the system problems remain
after reset, restore the factory settings and install again
Reset
: Press and release the reset button with a paper clip or thin object
Wait for the Network Camera to reboot
Restore
: Press on the reset button continuously for over 5 seconds
3helpful
I have a belkin f5d723-4 router that i accidentally set as a direct access point. Now i cant access the routers home page. Is there a way to reset the router?
Check on the back for a small hole you can stick a straightened paper clip into.
The "Reset" button is used in rare cases when the Router may function improperly. Resetting the Router will restore the Router's normal operation while maintaining the programmed settings. You can also restore the factory default settings by using the "Reset" button. Use the restore option in instances where you may have forgotten your custom password.
a. Resetting the Router Push and release the "Reset" button. The lights on the Router will momentarily flash. The reset is complete in 60 seconds.
b. Restoring the factory defaults Press and hold the "Reset" button for at least 10 seconds, then release it. The lights on the Router will momentarily flash. The restore is complete in 60 seconds.
Was trying to set a photo as my backdrop when after I pressed something which I don't remember which button... an error occurred, my all my apps were gone and apps error 523 pops in a white screen... I...
I experienced the same problem sometimes last week,and a simple master reset restored my BB back to a normal working condition but unfortunately after trying all the solutions i laid my hands on,but, i was unable to get all my applications back.
It sounds absurd,but the only solution now is to download all your applications again from the blackberry sites,believe me it didn't take much time as i expected.so sorry.
Good luck!!!!
Aug 02, 2010 • Cell Phones
2answers
How to restore my original phone settings on my handset nokia 6630
Here are the 2 steps that you can do in resetting your phone.
Normal Reset (*#7780#) : Restores ini files from rom but preserves user data (photos, 3rd party apps etc)
Deep Reset (*#7370#) : This reformat completely the C: drive. All applications and files stored on this drive will be lost and clean default files will be rewritten.
3answers
I can't reset my g mimo router
most of the time there is a small pin hole on the back of the router to be used to restore the factory default settings
How do I restore my computer keyboard? I was tring to add a symbol to the arrow up,down,left & right key and now it doesn't work. it just keeps moving to the right..I would like to restore it to it's...
Go to the system preference app, launch keyboard and mouse control and press the "Restore Default" button at the bottom of the page... you'll be back to apple normal!
1helpful
4answers
Cant remember my netgear network key
Reset and Restore the NETGEAR device to Factory Default Settings Problem: var js_3;function initPsDisplay(){js_3 = new PsDisplay({"info":{"controller_name":"PsDisplay","name":"PsDisplay_3","type":"FormField","w_id":3},"attrs":{"label":"","tabindex":"","field_name":"description","cf_id":"","table":"answers","highlight":0},"js":null});js_3.init();}YAHOO.util.Event.onDOMReady(initPsDisplay); Symptoms:
  • Forgotten/lost password to log into the NETGEAR device
  • Cannot access the NETGEAR device web interface
Workaround: var js_4;function initPsDisplay(){js_4 = new PsDisplay({"info":{"controller_name":"PsDisplay","name":"PsDisplay_4","type":"FormField","w_id":4},"attrs":{"label":"","tabindex":"","field_name":"solution","cf_id":"","table":"answers","highlight":0},"js":null});js_4.init();}YAHOO.util.Event.onDOMReady(initPsDisplay); Resolution:
If you have changed the default password and have forgotten the password, you may need to reset the NETGEAR device to factory default settings.
When a NETGEAR device resets, it goes back to the state when it was new — all information that was entered by hand is lost! Examples are critical things you need to get online, such as ISP username, ISP password, IP addresses, wireless security keys, and ports and services that were opened. It all needs to be re-entered.
So, have your ISP information before resetting the router.
Naturally, if you moved to a new city, or if you bought a used router, the old information in the router may not be of use to you. Contact your ISP if you can't connect any computer directly to the Internet.
Reset for most routers with a reset button on the rear panel
Write down configuration information such as IP addresses, security keys, opened ports and services, etc., that you modified. (The default username is admin and the password is either password or 1234. Try these before resetting the router.)
  1. Press the reset button on the back until the test light blinks. This takes about 10 seconds. (To avoid accidental resets, the small button is recessed. Use a pen or paperclip to access it.)
  2. Release the button.
  3. Wait for the router to reboot.
  4. Log in with the default password. If the router configuration was not cleared, try these additional steps AFTER the router has finished rebooting.
  5. Unplug the router's power.
  6. Press and hold the reset button. While the button is held down, reconnect router's power.
  7. Continue to hold the reset button for 20 seconds after reconnecting the power.
  8. Wait for the router to reboot.
  9. Log in with the default password.
Hope this helps.......
God Bless.......
1helpful
How to reset to original settings?
1. To restore the default setting you have to reset the calculator:
- With the calculator switched ON press the [2nd][+] [ENTER] Move the cursor down to Reset or press the [7] key.
-Choose to reset [RAM] ( 1: all ram; 2: defaults) or [ALL] (1: all memory. Whatever choice you make needs to be confirmed in a subsequent screen.
To reinstall the applications you need a TI silver cable, and the TI Connect software. Install the software before connecting the calculator to the computer.
Then you go to the education.ti.com web site Unfold the DOWNLOADS menu, choose Apps,Software,Updates submenu. Click TI83Plus/TI84PLUS family link and download what ever you want on your computer.
When you are done, connect your calculator to the computer, execute the TIConnect software . You can then drag and drop on the TIconnect window the app you want to restore.
Hope it helps.
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Jerry Naidoo
Paul Bade
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
