Try empty waste toner container located on the left hand side of the toner cartridges!Try empty waste toner container located on the left hand side of the toner cartridges!
You can't post conmments that contain an email address.
Is it a clp 315w. If so, it could be dropping off the wireless network. I had a similar problem caused by duplicate IP addresses. Removed the printer and re-added it to my laptops which resolved the problem. (Control Panel add/remove devices), Roy Bayliss
You're almost out of toner (depending on where the light flashes, that toner needs to be replaced soon). It also can be the waste bin, that is full, in that case you have to replace the waste bin by an empty one.
Hey angel!The best is to load the smartpanel software that's on the driver disk and see what smartpanel says about the problem,it can be anything from paper jam to toner low?Good Luck!
It is a color laser printer.it has 4 toner cartridge(1)black(2)magenta(3)cyan(4)yellow all cartridge is missing or toner finished.Please purchase full set toner.All toner cartridge has a image sensor.When toner is run out then it is out of work.
