Is the button stuck when u close the door maybe the machine is not sensing the door is closed
My pye machine wont spin properly and the clothes go into a ball in the middle instead of going to the outside of the bowl. Any solutions please?
This can be fixed yourself. I ended up cleaning out the pump and it had a coin in it. The barrel of the machine came loose and the belt broke instead of buying one for the actual machine for a couple of hundred dollars i went into super cheap auto or Repco and brought a cam belt for the size I required for under $20
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
