Danby DWC283BLS Wine Cooler Logo
Posted on Jun 02, 2011
Upper & lower level does not cool. Temperature stays at 78 for lower level & 75 for upper. In attempting to set cooler temperature at 55 for top and 45 for lower it immediately reverts back to 78 for lower & 75 for upper. Motor in back is hot but other parts don't seem to be running. In the past the top & or sides would be hot but not now. At least 10 years old
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jul 30, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
558
Points
Take shelves off. temp display unit in middle of shelf is where circuit board is for testing. pull middle unit forward and unscrew back panel. check lines for leak. color should look like a teal green. thats where your leak will be. Need tech. for the rest.......good luck!!!!
2006 Silverado, with a/c running and cold on both sides for 2 hours or so then the drivers side gos hot passengers side cold at the same time.
Manual or automatic climate control ?
Have you had the HVAC control panel checked for DTC'S - diagnostic trouble codes ?
Air Temperature Sensors
The air temperature sensors are a 2-wire negative temperature co-efficient thermistor. The vehicle uses the following air temperature sensors:
• Ambient Air Temperature Sensor
• Inside Air Temperature Sensor Assembly
• Upper Left Air Temperature Sensor
• Upper Right Air Temperature Sensor
• Lower Left Air Temperature Sensor
• Lower Right Air Temperature Sensor
A signal and a low-reference circuit enables the sensor to operate. As the air temperature surrounding the sensor increases, the sensor resistance decreases. The sensor signal voltage decreases as the resistance decreases. The sensor operates within a temperature range between -40°C (-40°F) to 101°C (215°F). The sensor signal varies between 0-5 volts.
The input of the duct air temperature sensors are different from the ambient and inside sensors. The HVAC control module converts the signal to a range between 0-255 counts. As the air temperature increases the count value will decrease.
• DTC B0174 Output Air Temperature Sensor (Upper Left) Circuit Range/Performance
• DTC B0179 Output Air Temperature Sensor 2 (Lower Left) Circuit Range/Performance
• B0414 is for the left air temperature actuator.
B0408 is for the left air temperature actuator.
DTC B0989 Output Air Temperature Lower Sensors Correlation
The HVAC control module monitors the upper left and upper right duct temperature sensors when the mode switch is in the VENT or BI-LEVEL positions. The HVAC control module monitors the lower left and lower right duct temperature sensors when the mode switch is in the DEFOG, FLOOR or FRONT DEFROST positions. The duct sensors are used to measure the temperature of the air exiting the ducts to help maintain a consistent cabin air temperature. These duct sensor inputs provide the HVAC control module a way to determine if the engine needs to be started to maintain a specific air temperature. If an upper duct sensor circuit failure is detected the HVAC module will not request an engine start to help cool the cabin. A lower duct sensor circuit failure will not prevent the engine from starting.
DTC B0990 Output Air Temperature Upper Sensors Correlation
Your best bet , take it to a qualified repair shop .
Why can't I lower my honeywell 8500 below 67 on cool?
With a two story house you have to be aware that cold air flows downwards so any cold air coming from an ac unit will flow downstairs( normally down the stairway) so unless you can close off the down stairs then the up stairs unit will be cooling downstairs as well. Ac units have a thermostat located in the air intake and it cools until the cold air has risen to that point. In effect the space above the ac unit will be hotter than the floor. Knowing how they work ,you can see that the upstairs unit will never reach the set temperature because the cold air is continually heating from the house and will never get to the top thermostat.
So your solutions are
1-- fit controls that restrict the cold air from leaving the upper floor (Doors)
2--don't run the upper ac unit unless you are living up there (waste of money
)3 place an ac in each upper room and keep the room door closed
Just purchased and is not cooling at all
please see this steps and fix it. God bless you
1. Unit not running
Possible Causes Response a. Power cord unplugged
b. No power at all
c. If display lighting, temp setting high
d. If temp setting ok, sensors or control board bad
e. Compressor unit malfunctioning a. Check for power cord plug
b. Check receptacle voltage & fuses
c. Lower temperature setting
d. Call service for replacing sensors or control board
e. Call service for component check
Cannot get Danby Silhouette 166 dual wine cooler to change temperature. It stays at 70 (both upper and lower). Can you help. Just bought used brought it home and it won't cool.
I also just brought home a used Danby Silhouette 166-bottle wine fridge and it is not cooling. Did you have someone come look at yours and did you get it fixed?
I need to lower the temperature
There is a thermostat that is seen on the unit , you will have to set the thermostat to a lower level. Also check if there is any gasket leak to confirm that the cooling does not stay.
Keep the cooler away from hot spots to encourage the cooling to stay.
How to start oven in PROPANE STOVE
Print the following infore for future ref if you wish. How it works is simple tage a look at it in Motion
Component Test Procedure Results
Electronic
range control
F1−1 –Upper Oven >650°F with door unlocked.............................
F1−2 –Lower Oven >650°F with door unlocked.............................
F1−3 –Upper Oven >950°F with door locked.................................
F1−4 –Lower Oven >950°F with door locked.................................
F1−7 –Membrane switch is not responding ...................................
F3−1 –Upper sensor is shorted at (< 100 ω) or
open at (>5 K ω) ...............................................................
F3−2 –Lower sensor is shorted at (< 100 ω) or
Check actual upper oven temperature,
if > 650°F check sensor.
Check actual lower oven temperature,
if > 950°F check sensor.
Check membrane switch for connection or damage.
Check upper sensor, harness, and connections
Engineering
Test Mode
Press BAKE pad.
Enter 100°F using the number pads.
Immediately push and hold BAKE pad for appropriate oven
approximately 3 seconds.
This mode can also be entered by pressing the hidden pad
for 3 second located to the left of the lower oven light pad.
Used to view the actual oven temperature for both ovens at all
times, even when an oven function is active.
This mode will also display the current fault code for 5
seconds in the time digits.
Fault codes
accessed
through
Engineering
Test Mode
F0−0 –No fault .................................................................
F1−5 –Upper hardware failure within control ....................
F1−6 –Lower hardware failure within control.....................
F1−8 –Shorted key in membrane switch ..........................
F1−9 –Internal communication errors within control .........
F1−A –Upper latch switches ............................................
F1−B –Lower latch switches.............................................
F1−C –Upper door switch.................................................
F1−D –Lower door switch.................................................
F1−E –Sensor input not calibrated ...................................
F1−H –EEPROM error .....................................................
F1−L –Temp in ovens are the same for long period .........
F1−N –Internal voltage on control not working .................
F9−1 –Upper lock switch is not correct.............................
F9−2 –Upper unlock switch is not correct.........................
F9−3 –Control does not see upper door lock....................
F9−4 –Lower lock switch is not correct.............................
F9−5 –Lower unlock switch is not correct.........................
F9−6 – Control does not see lower door lock ...................
EE –Control cannot read E-PROM. Unit will shut down.
Default from factory
Replace control
Replace control
Check membrane connection
Replace control
Check latch wire harness
Check lock wire harness
Verify sensor is operating properly
Replace control
Replace control
Check lock wire harness, and lock switch
Disconnect power for 60 seconds. If EE reappears, replace ERC
Test Mode This mode must be activated within the first 5 minutes of
power up.
Press BROIL and CANCEL pad for approximately 3 seconds.
If oven temperature is greater than 400°F, the Test Mode
cannot be activated or will abort if active.
Press and hold individual pads for 4 seconds to activate.
Display will have dashes in all segments to indicate the mode is
active.
Upper Bake: Energizes upper bake element
Lower Bake: Energizes lower bake element
Upper Broil: Energizes upper broil element
Convection Bake: Energizes convection fan
Upper Oven Light: Energizes upper oven light
Lower Oven Light: Energizes lower oven light
Upper Clean: Energizes upper motorized door lock
Lower Clean: Energizes lower motorized door lock
Stop Time: Energizes Beeper
Cook Time: Displays error codes
Timer 1: Energizes ROM version
Timer 2: Energizes EEPROM version
Keep Warm: Cooling Fan
Clock: All display segments light
If functions do not perform as specified, replace ERC
Oven
temperature
adjustment
Push BAKE pad.
Enter 550°F using the number pads.
To decrease or increase oven temperature. Push AUTO SET
pad until negative or positive numbers appear. Oven can be
adjusted from -35° to +35° (-37.2° to + 1.6° C) in 5° F (2.7° C).
To avoid over adjusting oven move temperature -5° each time.
Push OVEN CANCEL button.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
RADIATOR REPLACEMENT
  • At the time of installation, please refer to the following items.
  • Start the engine, and check for coolant and A/T fluid leaks.
  • Check the A/T fluid level.
  1. Drain engine coolant.
  2. Canada: Disconnect relay block (for daytime running light system) from battery hold-down clamp.
  3. Disconnect upper radiator hose from radiator.
  4. Disconnect lower radiator hose from water inlet pipe.
  5. Disconnect A/T oil cooler hoses from oil cooler pipes.
  6. Disconnect No.1 and No.2 cooling fan connectors.
  7. Disconnect No.1 Engine Coolant Temperature (ECT) switch wire connector.
  8. Remove radiator and cooling fans assembly.
    1. Remove the 2 bolts and 2 upper supports. Torque: 12.8 Nm (9 ft. lbs.)
    2. Lift out the radiator, and remove the radiator and cooling fans assembly.
    3. Remove the 2 lower supports.
  1. Remove A/T Oil cooler hoses from radiator.
  2. Remove lower radiator hose from radiator.
  3. Remove No.1 ECT switch.
  4. Remove No.1 cooling fan from radiator. Remove the 2 bolts and cooling fan. Torque: 5.0 Nm (44 inch lbs.)
  5. Remove No.2 cooling fan from radiator. Remove the 3 bolts and cooling fan. Torque: 5.0 Nm (44 inch lbs.)
INSTALLATION
Installation is in the reverse order of removal.
1helpful
Dose not get cold enough?
Does the compressor run or shut off when it gets to 55 &57? Leave unplugged over night and try again.. Let me know.
Top Danby Furniture Experts
ZJ Limited
ZJ Limited
Are you a Danby Furniture Expert? Answer questions, earn points and help others
