I had a problem where the rubber seal on the front door was janked off and water sipped into the machine. Now the Aqua Control system is activated, the pump continously runs and the machine wont start. How do I reset the Aqua Control system?
Thanks Guest! It worked perfectly lifting the face of your machine by 45 degrees
The washing machine was full of powder (this was the cause)
In our
case, the solution of tilting the machine also worked perfectly. The pump
was running continuously and the program did not start. However, the
EF0-message did NOT appear on the display. (Instead the remaining minutes were
given as usual, but - as I said - the program did not start). I concluded from
the manual that it had to do with the aqua-control and the manual advised to
contact the service-desk. Which I certainly would have done, if I hadn't seen
this page. Having
returned from holiday with bags full of dirty clothes, the last thing we could use
was a broken down washing machine. But
standing in front of the machine and pulling the upper side towards me (hereby
tilting the machine 20-30 degrees) made everything look normal. As it was late,
I took no further action. This
morning, I investigated the inside of the
machine. There was no water, but there was some dry material which might be dry
soap flocks. We may have put too much soap
in the machine (our clothes were very dirty) and the surplus of foam triggered the
aqua-control. After this investigation, I let the machine run with the wash in
it. No problem occurred. The machine
now runs normally. No need for the service desk, no estimated waiting time of
2-3 days and no estimated bill of 150 euros. Great!
1Don't even try to reset it. First the water must flow out of your machine. You could try to lift the face of your machine by 45 degrees to help it away. Then the EF0 flag automatically disappears and you can continue using your machine. Contacting the your local service center as the user guide suggests is strongly recommended.
SEEKING REMEDY FOR REACURRING AQUA STOP ACTIVATION
