Usually blink code on front gives direction but first thing to do would be to determine if surrounding sustain boards are causing draw on power supply by disconnecting them one at a time from power supply. y is on left looking from back and x is on right looking from back. if led goes solid with either board disconnected check supply voltages and if come up and stay up replace that board. if no change then you would need to verify vs on command coming from logic main to power supply. should be labeled on power supply connector and should be 3 volts. if present replace power supply if not present verify if logic main board sitting underneath signal board has one solid and one blinking led on if verifying normal operation and if so replace small signal board
SOURCE: Power Problems - won't turn on
first thing to do is determine if there is a blink code as that gives a direction for t/s. regardless, what you should do first is offload the y main and x main sustain boards from power supply one at a time as there is a common issue where these boards can cause load on power supply and if voltages come up with either one offloaded that board should be replaced before proceeding. if y main is the issue there is an upper and lower buffer board to left of that board and also should be replaced at same time as 3 boards complete a circuit and replacing one could cause damage to others.
ive the same problem on this plasma, turn it on comes into standby , press to power on and the standby flashes blue quickly,then back to red/orange flashes twice, then keeps lit,then flashes twice , help im based in liverpool ive a spare board what was ok but when put in this tv it was dead, no ive this one and it flashes
WHEN I TURN THE T V ON ,THE GREEN LIGHT COMES ON THEN AFTER ABOUT 5 SECONDS ,THE GREEN LIGHT GOES OUT AND A RED LIGHT COMES ON AND STARTS FLASHING. I UNPLUGGED THE UNIT AND REPEATEDLY FOR ABOUT A HALF HOUR AND AMAZINGLY IT DID COME ON AND REMAINED ON FOR A WEEK. NOW I'M BACK TO SQUARE ONE. HELP ME!
The power comes on and after about 5 sec the power shuts off and the red led light flashes 7 times, and will not work.
