Corporate Express CEB95005 Calculator Logo
Posted on May 04, 2011
Explain "CUT", "UP", "5/4"
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Mar 21, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
16299
Points
CUT: Values are cut off to the number of decimal places speicified by the current Decimal Place Selector setting
UP: Values are rounded up to the number of decimal places speicified by the current Decimal Place Selector setting
5/4: Values are rounded off (0,1,2,3,4 are cut off; 5,6,7,8,9 are rounded up) to the number of decimal places speicified by the current Decimal Place Selector setting
  • Anonymous Mar 21, 2013
tip
Live Mix - Kick Drum
I go to a lot of live gigs where the mix is all "there" but it lacks overall.<br /> <br /> Most engineers I find underestimate the importance of a really solid kick sound in their overall mix. The audience, while probably not knowing why, will respond much better if the kick drum has real presence.<br /> <br /> There is a simple way to do this:<br /> <br /> 1. Boost the Bass (as far as you can push it without clipping or "*******" for maximum "RUMBLE" )<br /> <br /> 2. Cut 315htz in the low mid (this is the "BOOM" sound, bad for a kick, fill it with Bass guitar)<br /> <br /> 3. Leave Hi Mids flat<br /> <br /> 4. Boost treble for good definition (The "CLICK" sound)<br /> <br /> 5. Build your mix around this. I like to have it up far enough so that you can feel the kick drum as well as hear it but not much louder.<br /> <br /> I will leave most of the other drums flat unless the toms are too boomy in which case I cut a little of the low mids in them. You can also add a bit of extra 2000htz to the snare for more "crispness".<br /> <br /> Remember a good live mix has a good wall of sound:<br /> <br /> (If youre going to boost, boost these approx frequencies depending on the room)<br /> <br /> Cymbals 5000htz-20000htz<br /> Snare 2000htz<br /> Vocal/Horns 500-3000htz<br /> Guitar 300-1500htz<br /> Toms 300-500hz<br /> Bass 100-400htz<br /> Kick 20-200htz, 5000htz-20000htz<br /> <br /> Another simple mistake is not having headphones, I see this all the time!! You need them to isolate channels so you can quicly find out where any unexpected problems/noises are coming from.<br /> <br /> Don't forget to have EQs on all your AUX/Monitor sends and Front of House to cut feedback!<br /> <br /> Hope this can help out any engineers starting out.<br /> <br /> Thanks,<br /> <br /> Doomface
1990 Camry ignition will not go under "acc" position.
In a Camry this age it is most likely that the key and lock both are worn. Toyota ignition key barrels are known to wear. Both old Toyotas I have had did this.
Go to an auto locksmith and explain that you want a key cut with a little extra metal on the profile, due to wear, and see if that works.
If not you need a new ignition key barrel (just the centre, not the electrical bits). It can be made to fit the old key, however you might decide not to bother doing that as it isn't much trouble to have 2 keys for the car.
Why would a 98 grand prix gtp transmission pull just fine for 5 milesthen quit cut off car put in nueatral 5 r 10 secs grank back put in gear pulls like a new 1 same thing over and over please explain
There are many things that can cause this, a bad transmission pump or torque converter, restarting the engine helps it because you are stopping the flow of oil and then restarting it oil starts to flow again and increase pressure as you accelerate ,
Another problem could be in the vanes of the torque converter with the same concept when you shut it down and restart it.
You would need a ****** shop to check pressure and put scan tool on it to watch readings, and last it may be low on fluid or internal leakage causing loss of pressure.
2answers
Freon leaked when put in. What is the hose called that is busted? Can this be fixed by purchasing the "classic tool design ac high-pressure cut-out switch kit"?
Your confused
If you have a leak, you have to repair
the hose assy etc
I am familar with classic tool design
but not the cut switch.
Explain that to me
You say hose busted,on what,your refrigerant
gauge manifold
2answers
What does "on battery" &
It's an auto lock setting wherein you can set the time when the display goes on sleep. If for example, it runs on battery and you want the display to go off after 5 minutes so you can save battery, you can set it to that. If it's plugged in charger and you don't want the display to go off, you can set it to never so it doesn't lock the phone and acts as a real alarm clock.
Mar 06, 2011 • Cell Phones
My screen does not cover the whole screen. It is not on widescreen mode, but it is a shortened picture and some of what I am watching is cut off.
A lot depends on what the TV station cuts off also.
If they are transmitting a 5 X 4 picture, your TV will try an reproduce it giving cut off edges or top and bottom. It won,t fit properly.
Hope that helps to explain it.
Top Corporate Express Office Equipment & Supplies Experts
k24674
Are you a Corporate Express Office Equipment and Supply Expert? Answer questions, earn points and help others
