If you're trying to scan for channels, this option should be found in your menu. I am not sure what your menu looks like, but usually there is a "Channels" setting in your menu. You can then select "Start Scan" or "Scan for Channels." You might also look for anywhere that says "Initial Setup" or somewhere in the menu that says "Add/Remove Channel." For some reason, Philips does not allow you to look this model up on their website. If you can't figure out the menu you should try calling Philips customer support.
LCD Television (2008 and newer)
1-866-771-4018
Televisions (purchased before 2008)
1-866-310-0787
