Moen & Replacement Cartridge  Logo
Posted on Apr 30, 2011
Need to replace moen cartridge 12801 with a new one. Is there any replacement or I should look for the 12801?
Abraham
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Nov 22, 2014
Abraham
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
25734
Points
16
Yes, there is... go to amazon here Amazon com moen cartridge 12801 and take a look. enjoy
Roger
Level 1:
New Friend:
  • Posted on Oct 31, 2014
Roger
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
25734
Points
11
Sure there is. Use this tool to check (find cheapest dealer with high quality product) http://tinyurl.com/cartridge12801wholesale Best of luck
jasmic11
Level 1:
Welcome Back:
Visited the website for 2 consecutive days.
  • Contributor 9 Answers
  • Posted on May 05, 2011
jasmic11
Contributor
Level 1:
Welcome Back:
Answers
9
Questions
0
Helped
28843
Points
15
The Moen 1222 is the cartridge you want. The 1222 is the OEM number, and the cartridge carries a lifetime warranty. If you call moen at 1-800-buy-moen, they will likely send you a replacement cartridge free of charge. Some wholesale plumbing suppliers will also do it if you act like you know what you are talking about, and they don't have an aversion to "retail" customers.
  • 2 more comments
  • RIGO TREJO
    RIGO TREJO May 05, 2014
    I was also looking for the 12801 replacement cartridge for my one handle kitchen faucet. Took the advice of jasmic11 and called the 800-buy-moen# and went through all the prompts and once i got to a cust rep they asked me a few ?'s and were nice enough to send me a replacement cartridge FREE of charge. It's $15.00 charge if u want it sent to u over night. I chose the free shipping. They also sent me an email with instructions on how to replace it and a shipping confirmation email as well. Goes to show that they do stand behind the product. 5-05-2014 1pm ct Rigo T. Chgo, IL
  • Rich Wheeler
    Rich Wheeler Mar 22, 2017
    NOOOOO!!! That's a typo, Jasmic11. The equivalent cartridge is the 1225. You can find 1225 replacements at almost any hardware store, but as Rigo said, Moen will send you one free.
    The 1225 is for a single-handle faucet (one handle for both hot + cold), whereas the 1222 is for two-handle faucets (one knob for hot, one knob for cold). They are not the same and not compatible.
    https://www.moen.com/customer-support/ca...
  • Jim Collins
    Jim Collins Nov 25, 2017
    A Moen 1225 is the cartridge you want. Use plumbers grease to ease installation of the new cartridge.
  • Anonymous Jan 31, 2018
    I have to agree with Jim. I just replaced my cartridge with a package labeled Moen 1225. Interestingly, on the new valve , is the 12801 number. In any case, worked perfectly. Thanks to all. A 12801 in no longer listed on Amazon.
1helpful
Will a Moen 1200 replace a 12801?
Oct 30, 2018 • Moen Home
2answers
Do any plumbing stores carry moen 12801 replacement cartridges
I am not familiar with that cartridge, but most hardware stores and plumbing supply houses should have Moen parts. #'s 1224, 1225, 1200 and 1222 are the cartridges I'm familiar with.Bring the part with you.
Replacement cartridge?
Hi, Try the #12001 It may solve your problem check to see if diameter is the same size.
Pulled a moen 96909 and replaced with a 1222. the 1222 does not go in the bore far enough to put the clip back in.
It sounds like you are experiencing an issue with the installation of the Moen 1222 cartridge in your faucet. The Moen 1222 cartridge is designed to be a direct replacement for the Moen 96909 cartridge, so it should fit in the same way. If the 1222 cartridge is not going in far enough for you to reinstall the clip, there may be a problem with the cartridge or with the faucet itself.
Here are a few things you can try to troubleshoot the issue:
Make sure the cartridge is oriented correctly: The Moen 1222 cartridge has a specific orientation that it must be installed in to work properly. Make sure that the cartridge is oriented correctly and that the stem is facing the right direction.
Check for any obstructions: Make sure that there are no obstructions in the bore or in the faucet that could be preventing the cartridge from being fully seated.
Make sure the faucet is properly disassembled: If the faucet was not properly disassembled before installing the new cartridge, it may not be seated correctly. Make sure that all of the internal parts of the faucet have been removed before attempting to install the new cartridge.
If these troubleshooting steps do not resolve the issue, it may be necessary to seek the assistance of a professional plumber. It is also possible that the Moen 1222 cartridge is defective, in which case you may need to return it for a replacement.
Jun 08, 2012 • Moen Home
18helpful
2answers
Need a moen 12801 cartridge
Sure, take a look on amazon: Amazon com moen 12801 cartridge. I hope this was helpful. Cheers
7helpful
How do I get to the valve cartridge to replace it?
how to replace moen cartridge for two handle kitchen faucet ... cartridge for two handle kitchen faucet exporters,how to replace moen cartridge for two handle kitchen faucet suppliers,how to replace moen cartridge ...cn-faucet.com/ kp-how-to-replace-moen-cartridge-for-two-handle...
3helpful
2answers
New MOEN 1222 cartridge leaks
remove it and carefully inspect it, you might have scuff'd up the rubber's on the cartridge when you inserted new one.clean out,look in hous'ing for any foriegn mat.etc .you may need another new cart.
Top Moen Home Experts
john h
Gene Lawson
deton8 von Splosion
Are you a Moen Home Expert? Answer questions, earn points and help others
