It needs reset. Using the remote:
1)Push "Set up"
2)Go to "System"
3)Go down to "Reset"
4) Push "Enter"
Assuming the player is fine, the 'Bad Disc' display message usually means either a disc which is an incompatible format (for example DVD-ROM) with this player; a disc which is a region that does not match that of the unit; or a defective/damaged disc. Check the discs prior to using them in this player and if they are burned discs, make sure they are a compatible standard format for playback.
This model is not region-free by default unless stated otherwise in the manual.
