Where can you find parts for this 2800 generator? Was ordered by father in law for emergencies over a year ago. never needed it until recently. went to start it and on the second pull, the plastic mechanism inside the top busted into many pieces. No one in my small rural area has heard of this brand, and since that is the case, will not attempt to locate the parts, either from the manufacturer or similiar parts from other engines.
The age of the machine is not as big of a replacement parts hinder as is Schwinn going through so many buy outs since 1988.
One of the best exercise repair parts on online is FitnessRepairParts.com. They have consoles which are similar to your generation of machine for 170.00 - 240.00
Otherwise schwinn was most recently owned by Nautilus/Bowflex/LAMAR fitness and they may be able to help through their website.
Sorry, I don't have a great source of imformation to help with. I repair Schwinn exercise and it has become very hard to find parts recently as the new generation of AEROdynes are very different. Although, up until maybe 1-2 years ago, nothing had changed for 30 years.
Alternatively, search craigslist and ebay. You may have to buy an entire unit to get the part you desire. Often they have a drive mechanism worn out which devalues them to the seller, but has minimal to do with your search.
I know this is an old post, but I just had this same situation. Inherited a unit from my father in law and it had be sitting about a year. I drained the gas tank (disconnect fuel line and pressurize tank inlet with shop vac) and flushed out fuel lines and replace fuel filter, air filter, oil and filter. Cleaned and lubricated all carb and choke mechanisms. Sprayed a bunch of carb cleaner and let it soak. Put in fresh gas. Cranked and cranked and cranked. Did not start right away, but stuck with it. I put some gas in a syringe used for injecting meat (just so you know the size) and remove everything above the carb venturi. Put about 1 cc of gas directly in the carb and cranked. it started and ran until that gas burned up (about 2 seconds). It ran ok but wasn't getting fuel so I suspected the fuel pump. Kept at it and repeated this about 15 to 20 times and noticed that it would run just a wee but longer each time. Until finally it caught and ran strong. Put everything back and it is in great shape. Hope that helps. Also, I noticed there was quite a bit of moisture in the muffler. This sputtered out until it got out enough to evaporate it all out. I now keep it covered when not in use - something I am not sure my father in law did.
send me a photo of the compressor and if there are any model numbers or serial numbers and I will see if I can identify the pump for you. my e-mail is [email protected]
NO. this camera has been out of production for over 20 years. Minolta quit the camera business 2 years ago. Best bet: search Ebay and get another that needs repair. Grab the batt holder from it and keep the rest of it fer parts!!!
