Buy a dewalt or milwaukee instead. no wobbles on either
I am using this tool for almost 2 years and I haven’t got any problem with it; I hope everything you have heard about this tool is just a myth. I prefer this https://studyclerk.com/ site to get writing tips and much more for students. This drils has a lightweight and very useful for drilling screws. Thank you for sharing this information.
SOURCE: changing a drill chuck
If this is a cordless drill open chuck jaws and remove the retaining screw (LH trheads), switch the clutch to drill only and shift gear selector to low. Insert a bent handle allen wrench about the same size as chuck (to keep from flexing) put chuck on workbench or block of wood and have the wrench about 30 degrees and strike the key counterclockwise to remove. You might have to hit a couple times but usually they will loosen up quickly. To install just reverse above. Let me know if I can help further.
Dave
SOURCE: bosch 18volt brute force cordless drill how do i remove chuck
Put the screw back in the chuck, tighten it up then back it out 1 turn. Take a punch, put it in the chuck and give it a quick hit with a hammer. That should do the trick.
SOURCE: I need to remove the chuck on my Bosch 33618 Brute
You must remove the inner chuck retaining bolt first, it is a torx screw and is left hand thread. once you have this screw out, get yourself a 1/2" allen key (the L kind). Chuck the short end in the chuck to grip it, use a mallet to hit on the long end (this will unthread the chuck). The spindle thread is regular Right hand thread. It may take a few good hits to knock it loose but it will come off.
SOURCE: Cordless Drill, Keyless Chuck stuck in full open position.
if chuck is wide open ,look down inside there should be an allen screw or bolt at the bottom of the chuck it should undo anti clocwise and the chuck comes off
SOURCE: Black and Decker Cordless Drill Chuck stuck in full open position
I'd put penetrating oil in it and tap the chuck with a plastic hammer. That should free it up.
Best rgrds, W/D
