Konica Minolta DiALTA Di200 Copier Logo
Posted on Aug 06, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Konica minolta matching paper size isnt available,put matching paper in the firts tray
  • 2 more comments
  • gerrith Aug 07, 2008
    I am struggling with my konica minolta printer(DIALTA DI552).Its giving me a error message "Matching paper size isnt available,put matching paper in the first tray.I have also put in paper in different ways in the trays.After i reboot printer it print 1 or 2 pages than error message popup again
  • Ralse Mar 20, 2009
    Have the same problem, but I know where it lies.
    My printer can not print below 92 x 184 mm yet I need 97 x 145 mm.
    Any way to change the drivers so it supports the same as any other printer? This is ridiculous, I need to print cards, they aren't really that small or odd.
  • Tim Babcock
    Tim Babcock May 11, 2010
    Got a question. Is this happening when your are printing out a pdf file with different page sizes that are greater than or less than 8 1/2 x 11?
  • Alexander May 11, 2010
    Can you please clarify what your problem is, and what you've tried to do? Be as detailed as possible.
Chris Coughlin
Level 2:
  • Konica Minolta Expert 1,326 Answers
  • Posted on Oct 09, 2008
Chris Coughlin
Level 2:
Answers
1326
Questions
Helped
441375
Points
872
How about this, if you look what paper tray are avaible from the display pannel, is there a matching size paper tray or is the tray you are trying to use another size then lets say LTR. Is it a different size, if so you may have paper jamed behind the paper tray causing a different paper size, if so remove the jamed paper..... Also, the other suggestion are good as well.
Print envelopes 350
was the computer os updated, 8.1 to 10 or ?????
try this
Self Help Product Support Konica Minolta Business Solutions Inc
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Aps error format
MATCHING PAPER SIZE IS NOT AVAILABLE.
Please select the proper tray and then press start button to make copy.
1helpful
2answers
No matching paper size set paper on bypass tray
Someone has told the machine to either make a copy or print from a PC to the Bypass feed tray on the copier. If you are not trying to print something by using the bypass tray then just turn the machine off, then on again to clear the request from the copier. If you are trying to print or copy from the bypass tray then simply insert the correct paper size and direction into the bypass tray slot and the machine should automatically begin printing.
Good Luck and Thank You for using Fixya.
1helpful
2answers
I have a problem with a bizhub c451
sometimes especially when printing a pdf there is a box on the first print screen that pos up that says print actual size deselect that and then it will default and print on the paper that is available
I am trying to print from my computer to the konica minolta c350 but i can't get the paper size right. How do i fix the settings
Very vague. but make sure the dial is set right on tray one to match the setting of your driver. (media type not size, but 8.5X11 thick 1 is not the same paper as 8.5X11 thick 2. The machine will tell you exactly what size and type you have requested of it. Simply Make the drawer match.
2answers
There are no matching paper size. Place paper in first tray.
A4 is n earupean size .change to 8 1/2 by 11 in both the copier and you printer setting..
3helpful
Konica Minolta paper mismatch problem
make sure that you specify the same paper size in the print dialogue window - i.e., in MSWord go file - print - properties - and make sure paper size in the dialogue box matches media type in printer tray
Cannot print Labels
The printer is setting the size from the position of the tray guides.
If it is reading it as K16 then that is the closest size to the paper you have loaded. The device will oook at the tray and then set it to the closest match this is the function of the Auto size feature.
Try measuring the paper and entering it as a custom size instead. Mimic the setting through the driver of course.
Run it through the bypass tray and be sure to specify the stock type/weight for proper printing.
Top Konica Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
