HP Photosmart C6180 All-In-One InkJet Printer Logo
Posted on Jan 17, 2018
My HP Photosmart Plus B209a-m prints out of line by 2mm which means I have to make adjustments to templates etc to print on specialist paper. i.e. where a left margin and right margins are set to 1.5cm I have to set left to 1.7 and right to 1.3 in order to fully centre the text or table on the page.
3 Related Answers
57 varieties
Karl Wright
  • 1653 Answers
  • Posted on Sep 30, 2009
SOURCE: printing a full page 'background' (design) with no margins
No. The official minimum print margins are as follows
print margin specifications
Top (leading edge)
Bottom (trailing edge)1
Left
Right
Sheet Paper
U.S. letter
.07 in. (1.8
.46 in. (11.7
.25 in. (6.4
.25 in. (6.4
mm)
mm)
mm)
mm)
U.S. legal
.07 in. (1.8
.46 in. (11.7
.25 in. (6.4
.25 in. (6.4
mm)
mm)
mm)
mm)
U.S. executive
.07 in. (1.8
.46 in. (11.7
.25 in. (6.4
.25 in. (6.4
mm)
mm)
mm)
mm)
ISO A4
.07 in. (1.8
.46 in. (11.7
.13 in. (3.4
.13 in. (3.4
mm)
mm)
mm)
mm)
ISO A5
.07 in. (1.8
.46 in. (11.7
.13 in. (3.4
.13 in. (3.4
mm)
mm)
mm)
mm)
Anonymous
  • 146 Answers
  • Posted on Nov 28, 2009
SOURCE: HP photosmart 8250 is printing different margins
ok..do us a favor here..try a test page from printer selection panel. just to make sure it's not the printer..you may need to re install new printer drivers.
Anonymous
  • 32 Answers
  • Posted on Feb 14, 2011
SOURCE: Printing Phaser 8550
This printer does not have full bleed aka zero margine printing capabilities. Sorry to be the bearer of bad news.
How to clean and align HP B209a printer
Every time I had this problem it was the printer head. Try removing the cartridges, then the printer head. Be sure the head is seated firmly. Try printing again. The printer head expires long before it's suppose to so don't be surprised if this is the problem.
How do i change the ssid on my photosmart plus b209a-m printer
Step 1: Click on Windows icon (bottom left hand screen)
Step 2: Select Devices and Printers
Step 3: Right Click on "HP Photosmart Printer Plus B209a-m"
Step 4: Select "Printing Preferences"
Step 5: Click on Tab "Features"
Step 6: Select "Printer Services" in the bottom right hand corner
Step 7: Click on tab "Network Settings"
What you click on there depends on what's wrong with your setup, I think. Mine had a "Configure Wireless" option where I was stepped through the process.
Good Luck!
I have a photosmart B209a printer that produces small lines on my pictures. I replaced the ink thinking it might be that easy, but no dice. Any ideas for cause and cure
I had a similar problem initially and the fault was with the photographic paper. The lines were very regular, just over 1cm apart. Once I switched to HP Advanced paper it cured it.
Ok i bought an HP Photosmart B209 but how can i scan a picture into my computer?
You can use the program that comes with the printer. Its called HP Solution Center. There you can view your printers status, etc.. In addition you can choose to copy, scan or print files.
Can't print envelopes made by "Greeting Card Factory" v7 on an HP B209a-m. Cards (.fgc file) print OK but envelopes (.fev files) won't print (envelope won't go into the print area; spoolvs.exe take 99% of...
The problem centered around the fact that the HP209 would only print 8.5X11 sheets from Greeting Card Factory. Any other size seized up the pring spool.
We're going to return the HP (We think it's defective) and get an Epson.
1helpful
Mismatch paper size error
Click on Print, then Properties, then features.
About half way down there is a drop down box under sizing options.
Click on custom
Create a name, and put your width and height in.
Click Save and then OK
Completely X out of the print options.
Then Click
File, print
on the bottom of that screen there should be a scale to paper size drop down box. Scroll to the bottom and your saved name and dimensions should be there.
You will have to setup each individual sized template ones and then just scale to fit each time. Hope this helps
k24674
Grand Canyon Tech
Grand Canyon Tech
