Yes , the machine can be converted to manual operation but will require a set of timers , switches and wiring so that the independent cycles of the program are controlled by these manual modes.
You will need to wire the motor to a timer, the input and drain to switches. All these functions protected by bypassing the door switch which will reset power only when door is closed.
Hello, I have a washing machine also with the same model, AWF71P (7kg capacity). The problem is ....the drain is not functioning properly. pls advice. thanks/rgds, nvc
hello,I have a washing machine also with the same model AWF-71P (7kg capacity) the problem is run and stop
