My Remote Control was all of a sudden stop working. When pressing the buttons there is no response and feel like dead. I changed the new batteries but still it is not working.
Ok I just dealt with the Sharp customer support for this problem.
1) You need to unplug the TV for 1 full minute and remove the batteries from your remote aswell (this will reset the system)
2) Hold the power button on the remote for 30 seconds with the batteries still out of the remote and the TV still unplugged
3) After the 30 seconds replace batteries then press every button on the remote beginning with the power button in order from left to right and top to bottom (same way you read)
4) Then plug your tv back in and try the remote again.... and the remote and TV should be back in sync.
Or, how bout you just make certain that nothing is placed in front of the infrared sensor on you tv... Maybe someone should have suggested that before telling them to do all this voodoo nonsense!
It may be voodoo nonsense but it worked...Thanks!
It worked for me, thanks!
Sounds crazy, but it worked... Thank You
After going out and buying a new universal controller since I thought my original controller had simply fried since it was older and then finding the new controller didn't work, I searched here to see if anyone else had this problem. I found this answer and IT WORKED! Since my new controller wasn't cheap, it's getting returned tomorrow... old controller is working great now! THANK YOU SO VERY MUCH!!!!!!
It worked for me too! Thank-you!
It sure did work
It worked. Thanks
did not work. think remote too old. no power button on the tv. now what????
Sadly this didn't work for me either - but - having said that - I have to hold the buttons down for about 5 seconds THEN it will change channel etc.
This works every time.. such a simple fix but so hard to find! Thank you
I will try this method.
However, what works every time for me is unplug the tv then back in and everything works but only for awhile so Im thinking it’s the tv.
Press the 0 button three times while holdin the power key.
I am having the same hassle, the remote will work then stop, I have changed batteries, and still same problem occurs. When remote stops working, it will work again if I turn the TV off at the wall and on again. My TV is just over 2 years old. I certainly won't buy a sharp again, I have never had this hassle with any other TV before. I see some people say doing all those steps work, but when you say it works does that mean you have never had the remote problem since then.
This worked
Throw it out and buy a new one it’s not worth the hassle of trying to get it fixed
These steps are bizarre but it worked out like charm.. Just follow the steps as it is in order to reset the sharp remote control
My sharp remote stopped working. the above methods didn't work for me. instead i managed to fix the issue by resetting the TV settings.
there are physical buttons on each TV on side. press menu and press down key and go to reset. at reset position press menu to reset the TV settings.
And wow the TV working again for the remote set.
my samsung remote model BN59-00609A stooped working all of a sudden
my Samsung LCD TV remote BN59-00609A barely 14 months old has stopped working suddenly. I don't see the transmitter blink when I operate and view it through my mobile phone camera.
same here
Thank you! This worked perfectly!
This worked for me too! Thank-you!
Hello, I need help with my sharp remote .
Because I try everything but can't turn on the TV or nothing.
Help
