You can't rotate the toner cartridges manually without potentially damaging the printer. To get the cartridges to rotate, close the door and go through the following sequence:
- Press Menu Select to get to the main menu
- Go to the Print Menu
- Go to the Quality Menu
- Select Replace Toner
- Use the arrows to select Black
- When the display says "Black" press Menu Select
- Press it again, the display should read "Open door and replace black toner"
Now the black toner should be positioned to be replaced, and you should be good to go!
Open the lid of the printer. Depending on the model, there will be two cartridges on the right, one for black and one for color.
Find the cartridge that is running low on ink. The black cartridge will be in black, the color cartridge will have a patch of color (usually green) on it.
Pull down on the black clamp that is holding the cartridge in place and slide out the used cartridge.
Open the package of the new ink cartridge. Remove the protective tape and slide the new cartridge into the printer.
Snap the black protective case back into place and close the lid.
