Konica Minolta magicolor 2400 Laser Printer Logo
Posted on Jul 31, 2008
Hp 4250n, 49.4c06 service error message - Konica Minolta magicolor 2400 Laser Printer
  • 1 more comment
  • rayp1967 Jul 31, 2008
    only way to get rid of message was cold boot, any recommendations
  • Anonymous Sep 17, 2008
    49.4c06 in a HP LaserJet 4200
  • Anonymous Dec 09, 2008
    Error 49.4C06 on HP LaserJet 4250dtn
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Jul 07, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
24547
Points
5
Hey guys
same error
start
run
cmd
net stop spooler
goto windows explorer
C:\Windows\System32\spool\PRINTERS
delete all print jobs
back to cmd window
net start spooler
hard power reset printer
error gone all working again
  • 1 more comment
  • Anonymous Mar 03, 2012
    IT WORKS.. Thanks..
    Got rid of head ache..
    IT WORKS.. Thanks..
  • SteveS
    SteveS Feb 26, 2014
    It worked for me as well. Thank you for your post.
Anonymous
Level 1:
Problem Solver:
  • Contributor 13 Answers
  • Posted on Jan 06, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
13
Questions
0
Helped
36365
Points
30
Most 49.XXXX errors usually indicate a firmware error. The firmware requires updating. You can do this by visiting hp.com and downloading the proper version firmware.
You can send the firmware update simply by downloading a version of a print to file software. This is by far the easiest way to send the file to the printer in my opinion. Even if the printer is networked, you can easily perform this update. DO NOT disconnect, power down, or send anything to the printer while the update is downloading. Send me email if you want some specific instructions to [email protected]. I hope this helps.
Anonymous
Level 1:
New Friend:
  • Posted on Nov 19, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
24547
Points
Got the same error on a HP Laserjet 2430. Firmware upgrade didn't resolve it. The above steps did fix it! Thanks.
4 Related Answers
Anonymous
  • 2120 Answers
  • Posted on Feb 06, 2009
SOURCE: 49.c02 service error message on HP laserjet 4100
General printer error. Unplug the power cord for 10 seconds.
Anonymous
  • 2120 Answers
  • Posted on Feb 03, 2009
SOURCE: HP laserjet 4650; displaying error 49, FF81 Service Error
Anonymous
  • 2306 Answers
  • Posted on Aug 11, 2009
SOURCE: how do i clear an 49.4C18 error message on a HP
Any of the 49 errors are from the formatter board, you may need new memory, or a new board. The machine doesn't reset from this error without a new board.
Anonymous
  • 21 Answers
  • Posted on Jan 07, 2010
SOURCE: HP LaserJet M1522 with error 49
on hp.com you can update the firmware and that should take care of it. its a free download
49.ff95 service error HP LASERJET 4250N
I would start by removing the old driver, and make sure the print Que is empty.
Did you upgrade the firmware? If not I would.
Sir, We have a hp laserjet 4250n printer since
Replace the fuser unit (they last about 75K pages in my experience)
1. Power down the printer and unplug it
2. Remove the fuser from the back side of the printer
3. Replace the fuser unit with a new one
4. Turn the printer back on
1helpful
How do i clear an 49.4C18 error message on a HP LaserJet 4250n?
2helpful
2answers
51.20 error message on HP laserjet 4250n printer
It is an error with the laser scanner unit
1 Press ( SELECT button) to continue.
2 Turn the printer off and then on.
3 Reseat the connectors between the
laser/scanner and dc controller
PCA (J83 and J84).
4 Replace the laser/scanner assembly.
See Laser/scanner assembly.
5 Replace the dc controller PCA. See
Dc controller PCA.
If nothing from above works and the printer is no longer in warranty, it is possible if the printer is being used in a very dirty or dusty enviornment that the lens and optics of the laser/scanner are so full of debris that the beam detect error occurs. You can remove the top cover and the big black box in the center is the laser scanner assembly. Remove the screws securing the top cover of the laser scanner and remove and clean up all the optics to include the main mirror in the front. I usually use a damp q tip and for the mirror I slide up from toner cartrdige shutter area and observe from the top as it cleans the mirror. Removing the complete assembly on this model is not easy since there are a couple of cables going to the dc controller which are difficult to remove so removing the top of the assembly is easier.
Here is the service manual:
http://www.feedroller.com/Store/Service%20Manual/LaserJet%204250-4350%20(%204200-4300)%20sm.pdf
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Setting margins on printer
Well, by now you may have found the solution, however, make sure that in MS WORD under File > Page Setup > A4 is selected, and if you still this prompt (error), just click on OK and proceed with printing.
The Laserjet Printers are capable to print upto 5mms from the edge of the border.
Regards,
Nikhil
2helpful
2answers
49.FF95 SERVICE ERROR
Please look on: http://www.fixyourownprinter.com/
There are much solutions of this problem listed ...
For example this (it see good):
http://www.fixyourownprinter.com/forums/printer/46157#1
HP Laser Jet 4250n by TLYNN (3/20/07 12:22 PM) reply + / -
Anybody know the error code "49. FF95 Service Error"
We can't get around this...
Firmware Error 49 by Stephen (edited 3/20/07 12:29 PM) reply + / -
It could be a bad job.
First disconnect it from your network and any PC it might be attached to.
Power cycle it, then if it goes to ready status try the built in test pages, do they work?
If the printer will go to ready status and you have a parallel cable with the proper connector, then you can try upgrading the firmware from a PC, you can also try to upgrade the firmware over the network.
More reading:
http://www.fixyourownprinter.com/search/forums?f=&q=49+4250
Re: HP Laser Jet 4250n by TLYNN (3/20/07 12:59 PM) reply + / -
Still won't go back to ready status. Turns on to the same error code....
Cold Reset HP Laser Jet 4250n by Stephen (3/20/07 1:03 PM) reply + / -
Try a cold reset, it will reset the JetDirect settings, but it's the next step.
Cold Reset:
Power off printer, wait about 5 seconds, then power it on, when asterisks start appearing on the display press and hold the check mark until all 3 lights come on solid, then use arrow keys to find cold reset and push check mark to perform the reset.
Re: HP Laser Jet 4250n by TLYNN (3/20/07 1:06 PM) reply + / -
Thank You so much for your help... but that didn't work either. Same error code showed up.
Re: HP Laser Jet 4250n by Stephen (edited 3/20/07 2:27 PM) reply + / -
Then you probably need to replace the formatter.
Do you have another printer you can swap parts with?
There is a slim chance the memory DIMM is bad, you can try it with the DIMM removed, if there is more than one DIMM you can try installing just one and then the other.
A 49 error indicates that the formatter could not understand or execute an instruction within a file or cannot interface with an accessory, DIMM, or EIO device. Troubleshooting 49 errors is done through process of elimination. First determine if the printer functions in a stand-alone mode then test communications to the printer.
These errors can be divided up into two categories; the associated troubleshooting depends on the circumstance the 49 errors are occurring.
A 49 error is always followed by Hexadecimal numbers, for instance, 49.00FF. The Hex code is a memory address. Most Hex codes are not documented.
Re: HP Laser Jet 4250n by dmzcompute (3/20/07 2:26 PM) reply + / -
I do not see anywhere where the printer has been disconected from everything. If you have not done so already disconnect every cable from the printer with the exception of the power cable and turn the printer back on and see if you get the error and if not report back here for further instructions.
Re: HP Laser Jet 4250n by Stephen (3/20/07 3:28 PM) reply + / -
You might also try disabling the embedded JetDirect.
To disable the embedded LAN port
Turn the printer power off.
Power on the printer and watch for the memory count to begin.
Hold down the SELECT (Checkmark) button, when you see the memory count begin.
Continue holding down the SELECT (Checkmark) button until all three printer control-panel lights flash once and then remain on. This might take up to 10 seconds.
After the message SELECT LANGUAGE appears on the display, press the UP ARROW button or the DOWN ARROW button until EMBEDDED LAN DISABLED appears on the display
Press the SELECT (Checkmark) button. The printer then continues its power-on sequence with the embedded LAN disabled.
If this works the JetDirect built into the formatter is bad, you can either replace the formatter, or buy an JetDirect to install in an EIO slot.
Re: HP Laser Jet 4250n by Trev Pearson (3/20/07 10:08 PM) reply + / -
The only other thing to try, before spending money, is to get the network administrator to clear the print queue for that particular printer and then turn it on.
The theory being that a 'corrupt' print job is still in the system and as soon as the printer is turned on, that 'corruption' floods the network card with garbage which promptly goes 49.
If the printer comes 'ready', great. Then do a firmware upgrade. If not, then you will have to spend money on a new formatter.
Regards
Trev
Re: HP Laser Jet 4250n by roadrunner178 (6/21/07 2:09 AM) reply + / -
hi.
With a cold reset ,my problem solved.
try this as a first solution.
thank you
Re: HP Laser Jet 4250n by Anonymous (7/31/07 1:20 AM) reply + / -
THANK YOU WERY MUCH
FROM TURKEY
ZAFER
Printer displaying 49.2F80 error message
http://forums11.itrc.hp.com/service/forums/bizsupport/questionanswer.do?admit=109447626+1230712112034+28353475&threadId=1203454
Author Subject: 49.2F80 SERVICE ERROR favorites_add.gif vanessa spinelli
Feb 14, 2008 00:50:36 GMT Hi,
I have an HP 2420d printer, and I keep getting the following error message:
How can I fix this? It usually goes away when I turn it off and back on, but it's annoying to have to do it so often.
Any suggestions?
Thanks!
Note: If you are the author of this question and wish to assign points to any of the answers, please login first.For more information on assigning points ,click here
Sort Answers By: Date or Points
Robert M. Stewart expert_small.gif Feb 15, 2008 22:36:20 GMT Unassigned 49 errors are the formatter. Network card? Swap it. Any extra memory recently? Remove it. razmat lighthouse.gif Feb 16, 2008 15:23:50 GMT Unassigned you could try to unplug from everything and just have it plugged by itself into the wall and maybe print some test pages to see if the error comes up at any of those points.then hook up via parallel and try to send some print jobs ,then hook via USB and send some print jobs and see if the error comes up at any of those points.this can can help narrow things down and point to the network or elsewhere.
like the previous poster said,sometimes something on the formatter can cause this issue,like a hard disk or network card,where removing these ,at least temporariliy to test can help.
if you have the internal network port(usually on the "n" model),then try a cold reset.if you have a hard disk you can also use a skip disk load option by holding the down arrow while powering on until all led's come on ,then use the arrows to scroll to "skip disk load".cold reset is similiar except,hold down the select(checkmark) button while powering on until all led's come on and the language option pops up on the display.then scroll to cold reset.
2answers
HP Laserjet 4250n printer error 59.00
Replace the main motor assembly. A qualified tech will need to do this.
Top Konica Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
