To graph a f o g problem input the g function for y1. Then for y2 input the f function, anywhere there is an x (or whatever your variable is) put y1 instead.
Graphing on a Number Line
Integers and real numbers can be represented on a number line. The point on this line associated with each number is called the graph of the number. Notice that number lines are spaced equally, or proportionately (see Figure 1).
Figure 1. Number lines.
Graphing inequalities
When graphing inequalities involving only integers, dots are used.
Example 1
Graph the set of x such that 1 ? x ? 4 and x is an integer (see Figure 2).
{ x:1 ? x ? 4, x is an integer}
Figure 2. A graph of {x:1 ? x ? 4, x is an integer}.
When graphing inequalities involving real numbers, lines, rays, and dots are used. A dot is used if the number is included. A hollow dot is used if the number is not included. Example 2
Graph as indicated (see Figure 3).
1.Graph the set of x such that x ? 1.
{ x: x ? 1}
2.Graph the set of x such that x > 1 (see Figure 4).
{ x: x > 1}
3.Graph the set of x such that x < 4 (see Figure 5).
{ x: x < 4}
This ray is often called an open ray or a half line. The hollow dot distinguishes an open ray from a ray.
Figure 3. A graph of { x: x ? 1}.
Figure 4. A graph of { x: x > 1}
Figure 5. A graph of { x: x < 4} Intervals
An interval consists of all the numbers that lie within two certain boundaries. If the two boundaries, or fixed numbers, are included, then the interval is called a closed interval. If the fixed numbers are not included, then the interval is called an open interval.Example 3
Graph.
1.Closed interval (see Figure 6).
{ x: -1 ? x ? 2}
2.Open interval (see Figure 7).
{ x: -2 < x < 2}
Figure 6. A graph showing closed interval { x: -1 ? x ? 2}.
Figure 7. A graph showing open interval { x: -2 < x < 2}.
If the interval includes only one of the boundaries, then it is called a half-open interval. Example 4
Graph the half-open interval (see Figure 8).
{ x: -1 < x ? 2}
Figure 8. A graph showing half-open interval { x: -1 < x ? 2}.
Your function is not correctly defined. If graph is function y=f(x), variable must be x; if graph is polar, variable must be theta, and if graph is parametric, variable must be t. This does not cover all possible cases. Check the graph type and the definition of the function.
You might have used an inappropriate variable name.
For functional graphs y=F(x), the independent variable must be X
For parametric graphs, the independent variable in the x_t and y_t functions must be t.
For polar graphs the independent variable must be Theta, and for sequence graphs, it must be the special wiggly n.
Once you select the type of graph, the independent variable is entered by pressing the key marked X,T, Theta, n.
If you want the table to be generated, you must use the table feature. You can generate a table also after you draw (graph) a function. Enter a function in the Y= editor, then press GRAPH or SHIFT GRAPH (TABLE). If you press GRAPH, you will see a graph. If you want the table and are not interested in the graph, press SHIFT TABLE.
After entering the first function to graph press the down arrow and when the cursor blinks after Y2 type in the second function you wish to graph. After you finished entering multiple functions make sure the graph setting under the window button are set correctly so every function will be visible at the interval you set. After that you hit Graph and you should see your graphs being plotted.
there are nomerous way to make a graph in c++. you just have to now the code for it.. abse on my knowlegde there are on "for loop" statement that can be use in making a graph in c++.
(1) if asking for graphing y= -2/3x+2, then press [diamond] [F1: Y=] type in .2/3x +2, see graph by [diamond][graph]
(2) if asking for graphing y= -2/3x+a, where a=3x, then first archive a=3x in Home screen by [home], type 3x [sto] a, then go back to y= menu, and type -2/3x+a in Y1
(3) if asking for graphing an equation that is dependent on 2 variables at the same time, use x-y-z axis (aka, change mode to graphing 3-D by [mode]graph [5:3D]) then enter desired equation in y= menu using Z function in terms of x and y aka z(x,y)= ...)
