I have a Beverage Air MT 27 and t isn't cooling. Sounds like the compressor ties to kick on but then doesn't. There is a click each time it tries to go on then clicks off. Almost as if there is a charge or signal being sent to the compressor but doesn't fully turn on the compressor. The fan and motor still run fine. There have been a couple times when the compressor starts for a second or two and then has tripped the gfci outlet it plugged into and then the whole unit shuts down. Any ideas?
Go to page 10 of this PDF=> MT Merchandisers (MT Series) If you do not have Adobe Reader Click=> HERE For Customer Service at Beverage-Air=> HERE Go through pg.10 and that should give all answers you need, Good Luck, Sea Breeze
Check if the compressor is running. If not, test for power to the compressor. If the compressor feels very hot, and you hear something clicking, then you probably need a new starting relay which is inside a little box on the side of the compressor. You might have to wait several minutes for the compressor to cool off before it will do its next "click-on" and "click-off" thing. If the compressor is cool, and there is power going to the relay, the overload (next to the relay) could be "open" (no continuity).
Does the skybox make noise (like your refrigerator starting a cycle)? If not, I would unplug it for a short while and let it set. Then when you plug it back up listen for noises on whether the compressor kicks on or not. If it doesn't then you can check the cap and relay board. Or have your compressor checked for operation and freon.
could be the start relay. could also be the compressor itself. need to either check continuity of compressor or use a compressor analyzer to see if shorted or open.
You'll need to check the back-pressure on the low-side of the system, you have a faulty compressor. If there is a condenser fan motor make sure it is running when the compressor is on.
Check the compressor to see if it is running. Is it too hot to touch. If so make sure the condensor has proper air circulation to cool it. If the compressor is cool to touch and running. There is a leak in the refrigerant sealed system.The compressor isn`t doing any work because there isn`t any refrigerant in it, therefore will not creat much heat. A humming and clicking sound is typical of an overheated or damaged compressor. If the compressor isn`t running and connot start. It could be a bad start relay on the side of the compressor or a bad compressor. If you can remove the start relay, shake it and listen for a rattle sound. If it rattles, it is bad.If not. then it is time consider the cost of a repairman verses the value of the appliance. Check the cost of repair to the sealed system or maybe even replacing the compressor.I hope I have been of some help to you.
