I have a wii so im trying to get this wpa code to get internet acess and i cant find it
try this trouble shooting guide. Please try the following troubleshooting:
Are you using WEP or WPA security on your router?
Log into the router using the default IP (consult your router's manual for assistance)
Locate the "wireless security" section of your router settings and find the WEP or WPA key.
If you are using 64-bit encryption, the WEP Key must be a 10-character key consisting of numbers or letters A through F.
If you are using 128-bit encryption, the WEP Key must be a 26-character key consisting of numbers or letters A through F.
The WEP Key must be a Hexadecimal (0-9, A-F, no other special characters or letters).
If your router has multiple slots for a WEP Key, make sure the active key is the one in the #1 slot.
If you are using WPA, the Wii console is compatible with the following types:
WPA - PSK (TKIP)
WPA - PSK (AES)
WPA2 - PSK (AES)
If your WEP or WPA key is correct, then the problem might be related to MAC address filtering:
From the router settings, locate the "MAC address filter" settings (also known as "access control", "access list", or "network filter" depending on your router model).
If the Mac address filter is set to "enabled", then you must add the Wii's MAC address to the "allowed" list. You can locate the Wii's MAC address from the "console information" page (located under "Internet" in the Wii Settings).
If the Mac address filter was disabled, then continue troubleshooting.
Check Nintendo's router info for special notes, if available, for your router.
Click here to go to our Wireless Router lookup page.
Use the drop-down box to select, if available, your router manufacturer.
Click on your router's model number, if available.
Read any "special notes" at the top of the router's page. Many issues can be solved by changing settings described in the "special notes."
Try a "Manual Setup" with the Wii console (how to), using your network's IP configuration settings. To access these settings:
On your PC, click "Start" and then "Run."
Type "CMD" into the field that appears to open a new window.
Type "IPCONFIG/ALL" and press "Enter" to display a list of internet settings. Locate the settings asked for by the Wii console during the Manual Setup process and enter them.
Power cycle your router and modem by unplugging them both from the wall. Wait a few minutes, and plug the modem back in. Wait a couple of minutes for the modem to initialize, then turn on the router. Try to connect the Wii console online and test for proper response.
if you require further assistance please let me know and i will be glad to assist you. -Midwest-tek
