SOURCE: Water filter indicator light
On my samsung I needed to press the ice timer and ice mode together for 3 seconds.
SOURCE: Galaxy 2000 RS Remote Starter
go to bulldog security.com and look for your vehicle under free wiring diagrams
SOURCE: Viper won't remote start and arm/disarm only works sometimes
Greetings Microluv,
Simple question, have you changed the battery in your remote lately? I was having similiar issues with my remote start and it was a simple matter of changing the batteries in the remote.
I figured lets eliminate the easy stuff first. :)
Dorothy
Go Ahead. Use Us.
SOURCE: Valet 473T remote
It sounds like the system needs tach sensor reprogramming. The remote start system may have a tachometer sensing mode where the system "knows" that the car is running and to stop cranking the starter when when the engine is running. Generally when the vehicles battery is disconnected the system "forgets" the setting of the tachometer at idle which is programmed at the time if installation. Take it to a remote start installation store for this or get a hold of a maual for your system and shouldnt be too dificult to program.
SOURCE: REMOTE STARTER NOT WORKING COMPLETELY
Here is page 2 of the owners manual, Hope it helps.
This will not start the vehicle if any one of the following situations exists;
The vehicle's hood lid is opened.
The gear shift selector is not in Park.
The brake pedal is depressed.
The safety control switch is in the Off position.
1. To start the vehicle, press and release the transmitter button two times within 2
seconds. The vehicle will start and remain running for the pre-programmed 5,10,15,20 minute run cycle. As a visual indication, the parking lights will flash or remain on depending on the setting by your installation center.
2. When you arrive at the vehicle, turn the ignition key to the ON position (not the spring loaded start position), then step on the brake pedal to disengage the remote starter. The
vehicle will continue to run, but now on it's own power.
NOTE: The engine will stop running before the pre-programmed run cycle has expired if you perform any one of the following functions;
-Press and the button on the keychain transmitter two times within 2 seconds.
-Depress the brake pedal.
-Open the vehicle's hood
-Place the unit in the safety control disabled mode.
PRLED SAFETY CONTROL SWITCH
The Push-Button LED control switch allows you to temporarily disable the remote starting function of the system. This recommended whenever the vehicle is being serviced. To place the system in the service mode:
1) With the system disarmed/unlocked, and the ignition switch off Press and Hold the PRLED on.
2) Turn the ignition switch on, off, on, off, on, off.
3) The LED begins to flash two short flashes followed by one long flashes and continues this pattern until returned to normal mode of operation. This puts the unit into the R/S Override mode indicating that the remote start is in the service mode and will not start from RF or any other input Posse or otherwise.
To Exit R/S Override Mode
1) With the system disarmed, Press and Hold the PRLED on.
3) The LED turns off indicating that the R/S unit is fully functional one again
Programming the Viper Remote Starter 5101
Unlock the doors before starting
Push and hold f button for 8-10 seconds until amber light is on solid
Push Remote start button for about 4 seconds till amber light flashes 3 times
Put key in IGN to the on position but don
