This calculator is incapable of displaying simplified fractions (i.e. 1 ½), you will have to use the decimal value or contain your complex fraction in parenthesis. (i.e. (5/2).)
Unfortunately this calculator does not have built in support to convert from decimal to fractions.
If you are trying to complete fraction calculations without converting the answer back to a fraction format you can always use the standard addition, subtraction, multiplication and division functions with the parenthesis to get the desired result.
For example if you are trying to 1/5 and 3 3/4 you would type 1 / 5 + 3 + (3 / 4) =
You should get 3.95 as your answer.
The TI BA-II does not have "Fraction Key". In order to use fractions you must use the parenthesis to surround the denominator and numerator. For instance, if you wanted to use 3/4, you would enter:
(3/4)
