Casio WVA105HDA Wave Ceptor watch Logo
Posted on Jul 26, 2008
Casio wave ceptor WVA-105H
Setting and using the alarm function on casio wave ceptor watch WVA-105H
  • Anonymous Mar 15, 2014
    change battery wave ceptor 3045
  • Anonymous Mar 21, 2014
    what more do u want, watch is suppose to reset it self at two am every to correct time, since i ha anew battery installed 4 days ago it dosent set to the correct time its 15 minutes fast.
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Nov 10, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
5552
Points
18
Why does my Wave Ceptor WVA-105H work sporadically after getting wet?
Try a new battery. When water got in there it may have shorted the battery and drained it. It may work for a short time and then die. Also put the watch on you car dashboard in the sun to bake it instead of the oven unless you have an electric oven. For electric oven use a thermometer to get temp of 140 F then turn the oven off and put the watch in for an hour.
Problem with WAVE CEPTOR watch band
http://world.casio.com/wat/download/en/manual/
There are so many applications use of the manual will be mandatory.
Use the four numbers on the back of your watch and you will have a PDF version of your instruction manual.
Hope this tip helps
R/
David
http://antiqueclock.clockstop.com/
12helpful
How can I set time for my casio wva-105h?
The digital display sets itself, so I presume that you mean that you want to set the hands.
To do this, press the lower button on the left hand side until "HS" appears.
Use one to the buttons on the right hand side to advance or ****** the hands.
4helpful
2helpful
Do not have the manual to wave raptor wva-106hr
Paste this link into your brouser and follow instructions:
Do not forget to rate, please.
2answers
Setting my watch
Hi go to www.casio.com/support under technical support choose manuals.
1helpful
2answers
Waveceptor watch WVA 105H. Reception indicator had disappeared from the display this morning, so I attempted a manual receive. After about 5 minutes the flashing display was replaced with...
I have a wave ceptor casio watch 2734 model WVA 105H, however I've lost the manaul. I have a problem, the digital time reads correctly but analogue time is incorrect. How do I move the hands to the correct time? If you could find a solution it would be most appreciated.
Top Casio Watches Experts
k24674
Robert
ZJ Limited
ZJ Limited
Are you a Casio Watch Expert? Answer questions, earn points and help others
