SOURCE: Motherboard problem
Hiw can u say's its display problem,Have u checked the signals on k/b ?
If not check the Num lock status in keyboard. Press the Num lock key ,if the light glows and stands for sometime display is ok,but ur vga adapter is the problem.
Otherwise problem maybe with m/b or psu.
Pl check it.
Regards.
Was this soultion useful?give the apppriciation by rating it.
SOURCE: when turn on pc it wont come out of sleep mode
make clear you have conected every cord onto its original position. be sure that cooling system works. some computers get stuck when they get too warm too quick.
SOURCE: Graphic card
Beeping and no video means that the card failed to come up, and the bios is letting you know. try another card, or test that card in another system.
SOURCE: Hi I have problem with graphic
http://support.amd.com/us/Pages/AMDSupportHub.aspx
With your graphics card you want your drivers to be fom AMD/ATI. THis is their driver site. The way mine is hooked up is through yhe DVI port with "ATI" DVI to HDMI adaptor with HDMI cable. This may not aaplt to you. Anyway, whenever you are upgrading anything fom AMD/ATI, you have to uninstall all of the priohttp://www.txcesssurplus.com/servlet/Categorieshttp://www.txcesssurplus.com/servlet/Categoriesr software first through the best way is CCC. Uninstall al ATI first, then go to above website and, in the window, upper right corner put in;
1 "Component catagory" scroll to desktop graphics and select
2 "product line" scroll to Radeon HD series and select
3 "Product model scroll to RAeon HD seriesxxxx PCIe and select.
4 "operating system" pick your system.
Click see results and the first download should be the one you want. Download and install, restart system and it should work. you can get sound through that card with the ATI adaptor
