Zenith ZDA311 DVD Player Logo
A
Anonymous Posted on Feb 07, 2011
HI HAVE GOT A SAMSUNG PLASMA SERIES 4 PLUS, MY SON PLAYED AROUND WITH THE REMOTE AND NOW WHEN I PRESS THE SOURCE BUTTON AND GO TO AV ITS SHADED GREY, WHEN I PUSH IT WRITING COMES UP THAT SAYS THIS SOURCE IS NOT CONNECTED, WE CANNOT WATCH DVDS OR PLAY THE WII!! PLEASE HELP US!!!
Anonymous
Level 3:
  • Master 699 Answers
  • Posted on Feb 07, 2011
Anonymous
Master
Level 3:
Answers
699
Questions
Helped
218445
Points
2363
How to unlock dvd
Here is how to unlock the HT-DS1000:
Step 1) Disconnect your player from its power source for 30 seconds
Step 2) Reconnect your player to its power source
Step 3) Press the Power On button on your remote control
Step 4) Press the Enter button on your remote control
Step 5) Press the 8 button on your remote control
Step 6) Press the 4 button on your remote control
Step 7) Press the 2 button on your remote control
Step 8) Press the 6 button on your remote control
Step 9) Press the 9 button on your remote control
Step 10) Press the Enter button on your remote control
Step 11) Your player should now place itself in Standby mode
Step 12) Press the Power On button on your remote control
Please rate my answer if this helps,
Many thanks,
Chris
tip
Input Switching issues Harmony Remote and Samsung TVs
The following 2008 Samsung TV’s have Anynet+:
LCD
All 9 Series LCD TVs (LNxxA950)
All 8 Series LCD TVs (LNxxA850, LNxxA860)
All 7 Series LCD TVs (LNxxA750)
Most of the 6 Series LCD TVs (LNxxA650, LNxxA630) excluding the 19” and 22” models
All of the 5 Series LCD TVs (LNxxA550, LNxxA540, LNxxA530)
Most of the 4 Series LCD TVs (LNxxA450) excluding the 19”, 22”, and 26” models
Plasma
All 7 Series Plasma TVs (PNxxA750, PNxxA760)
All 6 Series Plasma TVs (PNxxA650)
All 5 Series Plasma TVs (PNxxA550, PNxxA530)
Half of the 4 Series Plasma TVs (PNxxA450) excluding the 410 line (PNxxA410)
DLP
All 7 Series DLP TV’s (HLxxA750)
All 6 Series DLP TV’s (HLxxA650)
All 5 Series DLP TV’s (HLxxA510)
2007 Samsung TVs With Anynet+
The following 2007 Samsung TVs have Anynet+:
Note: Excluding all 26" models and below.
LCD
All 81F series (LN-Txx81F)
All 71F series (LN-Txx71F)
All 65F series (LN-Txx65F)
All 61F series (LN-Txx61F)
All 53H series (LN-Txx53H)
Plasma
FP-T5084
FP-T6374
HP-T4254
HP-T4264
HP-T5054
HP-T5064
DLP
All 89S series
HL-Txx89S
HL-T7288W
Information on Samsung TVs that support AnyNet has been refered to from: http://ars.samsung.com/customer/usa/jsp/faqs/faqs_view.jsp?isARS=Y&SITE_ID=1&AT_ID=18104&ARS_ID=8514159
How To Disable Samsung Anynet+ so your Harmony Remote Control properly controls your devices. This mainly impacts Input Switching.
1) Press your Tools Button.
2) Scroll down to Anynet and press your Select Button.
3) Once on the Anynet screen, please press your Left/Right Button(s) to select the Off Setting on the Anynet+ (HDMI-CEC)
4) Scroll down to the Auto Turn Off and select No.
Once this is completed, please turn off your TV and all device and power them back on using the Harmony Remote. Also please test this in the Activities mode, if this does not work, let me know
tip
Input Switching Issues with Harmony and Samsung TV's
LCD
Plasma
DLP
LCD
Plasma
FP-T5084
FP-T6374
HP-T4254
HP-T4264
HP-T5054
HP-T5064
DLP
All 89S series
HL-Txx89S
HL-T7288W
Once this is completed, please turn off your TV and all device and power them back on using the Harmony Remote. Also please test this in the Activities mode, if this does not work, please e-mail us back for further assistance.
I have a Plus UP 1100 and the remote control was lost. How can I switch from video mode to computer mode manually?
hi,
you can select the RGB mode (computer mode) by the following without remote.
1. press the menu button
2. with up arrow or down arrow select source menu and press enter
3.press up arrow or down arrow to select RGB AUTO and press enter
4. press menu button to exit menu.
ok
I have a Polaroid 42" TV and the screen does not
if its a hd tv try viewing a true hd source and the grey areas should go away. you might have and resolution button on the remote that will toggle between screen modes. look for that button and give it a whirl and also make sure yoiu view a true hd program
5helpful
3answers
How can i turn on the av channel on a sony trinitron KV-25F1U
Hi, look for a symbol either on the front of the TV or remote that shows a Circle with an arrow pointing into it from the left
I just bought a second hand sumsung tv with a vrc attached. it has A/V connections but for some reason i cant hook it up to my dvd player...not sure WHY!?
connect up your scart lead, from the scart socket on dvd player to the scart socket on tvyer. There are usually to sockets to connect to on the tv, it will be AV1 or AV2. To view dvd, press source button on tv remote to select AV channel you have connected the dvd played to.
6helpful
Region codes for Samsung ht z110
Try this
1. Disconnect your player from its main power source for 30seconds
2.Reconnect your player to its power source
3.Press the power on button on your remote control
4.Press the Enter button on your remote control
5.Press 8,4,2,6 and 9
6.Press Enter on remote control and the your player will place itself on standby mode
7.press the power on button on remote control.
your player is multi region.
BLANK TV
hi, what you need to do is find the source button or av button on your remote control as it sounds like its changed source this causing your problem. As you probably know your telly has many inputs for dvd vcr cable or sky but these plug into one of the inputs in the back of telly. Usually the problem is just that your on the wrong input channel like av1 instead of av2 or rgb their are many inputs so you might need to press this button 2 or 3 times till you get the right channel, i dont mean 1 to 9 channels i mean input channel like rf input or av input. This depends on what your getting the signal from if its cable and its plugged in via scart lead then it will be an av input but you might have av1 av2 av3 av4 this depends on your telly.
If your still having problems then give me a shout back ok best to check all the leads are in the telly correct as this will cause the problem your having ok.
Let me know how you get on ok or if you need further help
2helpful
Regional code change for a samsung ht-db120n
1) Disconnect your player from its power source for thirty seconds 2) Reconnect your player to its power source 3) Press the Power On button on your remote control 4) Press the Enter button on your remote control 5) Press the 8 button on your remote control 6) Press the 4 button on your remote control 7) Press the 2 button on your remote control 8) Press the 6 button on your remote control 9) Press the 9 button on your remote control 10)Press the Enter button on your remote control 11)Your player should now place itself in Standby mode 12)Press the Power On button on your remote control. Your player is now region free. A word of caution is that you may have disc eject issues, in which case you will have to eject from the unit, or toggle the power switch on/off. This issue only arises if you have a particular chipset in your player (about a 20% chance).....good luck my friend.
Top Zenith Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
