SOURCE: How do I replace the door seal to a Bosch Front
To change the seal the easiest way is to take the front of the appliance off. Remove the kick plate at bottom and you will see some screws holding the front panel on remove these Then open door and remove the screws holding the door lock on and unlip the seal by releasing the clamp on the front. The front should now lift off, if it doesnt then pull out the soap drawer and behind that at the bottom of the drawer is a screw holding the front on remove this then push the front panel down then it will lift off You can now take the clamp holding the seal to the tub off. Fit the new seal, fit the clamp to the seal and tub. From here, rebuilding is the reverse of the strip down.
