Samsung HLP4674W 46" Rear Projection HDTV Logo
Posted on Mar 04, 2018
I have a samsung dlp4674wx/xaa. I had replaced the bulb about less than a year ago. now when i turn the set on, it will shut off after maybe 10 minutes and all three indication lights are flashing. i thought it may be the lamp and replaced it, but problem still exists. please help..
5 Related Answers
Anonymous
  • 50 Answers
  • Posted on Aug 11, 2008
SOURCE: Mitsubishi DLP - model #WD62725
you have mention that after 10-15 seconds T.V starts up, will you give total description of the T.V within that 10-15 seconds?
TONY BIGNELL
  • 147 Answers
  • Posted on Apr 15, 2009
SOURCE: TV won't stay on. Green & Red light timer-lamp (Green) stand by/temp (red) flash.
Most likely needs a new lamp. Easily done yourself.
Anonymous
  • Posted on Feb 04, 2010
SOURCE: samsung hlr6156wx/xaa, will not turn
samsung hlr6156wx/xaa, will not turn on, lamp button flashes and attempts to turn on, fan kicks in, then all three lights flash after a couple of attempts
Anonymous
  • 231 Answers
  • Posted on Apr 16, 2010
SOURCE: I have a Samsung HLT5076SX/XAA. The TV will
make sure lamp door is fastened closed, if this helps please give me high rating
Anonymous
  • 5138 Answers
  • Posted on May 01, 2010
SOURCE: Samsung HLN5065W..no picture, TV won't stay on, 3 flahsing LEDs.
Lamp Fan, make sure all fans are running if they run for alittle while and stop Fan is defective.
2answers
Samsung HLR5667wx/xaa. Power surge took out tv. Replaced bulb and the bulb works, but tv wont come on and lamp light is flashing.
Hello, it sounds like the color wheel may have failed. Was there any noises, like a high pitch sound before it went out? If the color wheel isn't turning at proper speed, the set won't start up by shutting down the lamp protection circuit.
Samsung HLS5086WX/XAA made popping noise and shut off, then made whirring noise.
When my TV did this in the past it ended up being the color wheel. I had someone replace it and it worked fine. I asked it if had to be calibrated after it is installed and he said no. Also make sure the door switch is pushed down when you install the back bulb door. Sometimes this switch can go bad as well.
Samsung HDTV - HLR5067WAX/XAA - popped, went dark
You had a surface mounted capacitor (AKA "CAP") let go on one of the circuit boards, open the set up and look for a small burnt area on the circuit boards inside the TV, it is likely it will be the power supply board, but that is just a guess..
I have a Samsung HLP4663wx xaa that I just replaced the color wheel to fix the buzzing noise and then had to replace the lamp after 16541 hours so definately got my moneys worth. Had to remove the jumper...
I would assume you need to replace that ballast. Usually the bulbs out live the bulb's ballast (from previous experience)...I've seen DLPS do this type of thing when the bulbs are slow to turn on due to a new ballast being needed.
Thanks and hope it helps!
Samsung HLS5687W XAA will not stay on
You might have the problem with your standby processor on it, that needs samsung technicians.
1helpful
2answers
Samsung HLS5086WX-XAA after 1 years it's showing dark
Light Engine or the DMD board 1-800-638-3328
3helpful
Television shuts itself off
i had the same problem with my set shutting off and was told it may be the ballast so i changed that but it still would start up and shut down after a few mins, then i was asked if the bulb had been changed and i had not, so i did change the bulb and have not had it shut down yet. :) (so try a new bulb)
We have a Samsung HLP5674WX/XAA which seems to have a mind of it's own. It will automatically shut off or when we turn it own, there will be no picture with sound or once it turns on, the TV will shut...
I have a Samsung HLP5474WX/XAA. The ballast was replace 2 months ago. I just installed the lamp, i notice green flashing occur on the LAMP when i turn it on. The tv takes 10 to 15 second to turn on the picture, the sound as soon as i power up i can hear it. Any advice??
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
