SOURCE: 1997 Polaris rmk 700 has no spark. Kill switch is
try bypassing the kill switch and the ignition switch. Often the switches fail before the other components. the ignition can usually be bypasses by simply unplugging it from the harness. You may have to loop the wires to bypass the kill switch.
SOURCE: 97 xc headlight dims then comes on also when it
Trace the wiring from the earth side of the headlamp, you have a high resistance earth wire maybe corroded where it fixes to the frame.
SOURCE: blowing low and high beam
Have you replaced your voltage regulator recently. This is usually a good indication that it should be changed
