Texas Instruments TI-84 Plus Calculator Logo
Posted on Jan 15, 2018
Error on TI-84 Plus calculator: "Please install operating system now."After a few moments: "Error: Press any key and turn unit off. Then turn unit back on". I did this and starts to download, OS, but after a few minutes, calculator shuts off and does it all again. How do I fix it?
5 Related Answers
Anonymous
  • 30 Answers
  • Posted on Oct 21, 2008
SOURCE: Scroll up
Sorry dude but u cant do that. There is no way around it... Youll have to wriite them down or something.
Anonymous
  • Posted on Jan 27, 2009
SOURCE: TI-84 Plus HUGE PROBLEM, will not reset and will not let me do anything on it
on Windows:
  1. Download OS from internet
  2. save in a folder
  3. right-click on the OS file and click send to TI Device
  4. Wait for Com to locate device
  5. Highlight Device and click select
  6. Then install
  7. if message comes up say OK
Hope this helps
i had the same problem
Anonymous
  • 11 Answers
  • Posted on Mar 18, 2009
SOURCE: comma key on TI-84 Plus Siver Edition calculator.
The comma key on the TI 84 SE is above the 7 key, and it is just left of (, right of x squared, and below SIN. thats where the "," key is. If you're asking something else, please clearify. My understanding is that you don't know where the comma key is.
gdcroft
  • 192 Answers
  • Posted on May 29, 2009
SOURCE: Find the antilog on the TI-84 Plus for finding pH in chemistry problems
I'm not specifically familiar with the TI83 or TI84 but I've used a lot of TI calculators in my time, so I'll give it a try. If your trying to find the antilog of a number in base 10 enter the number and hit the (10 to the X) button. If you're trying to find the antilog of a number in in base e (natural log), enter the number and hit the (e to the X) button.
Anonymous
  • 33 Answers
  • Posted on Jul 17, 2009
SOURCE: Dark screen on my TI-84 plus. What to do?
Press the 2nd key (yellow one) and then press the UP arrow to increase brightness or down to decrease but seems like you to need to press UP arrow.
HELP!! afther I connected my TI-84 plus to my pc, it keeps saying: waiting... Please install operating system now. than it says ERROR! Press any key to turn unit off. then turn unit back on... I've tried...
You cannot get the calculator to behave as you describe just by connecting it to the computer. You must have done some other manipulations.
Try to find a classmate who has the same calculator (TI84 Plus or TI84 Plus Silver Edition) and effect a transfer of the OS from the classmate's calculator using an IO cable.
1helpful
Texas instruments TI-83 Plus won't turn on. I have replaced the AAA batteries.
Check that the batteries are correctly inserted.
The screen may be too light to see anything.
To darken it
Press [2nd] key and release it.
Press and HOLD [UpArrow] till it darkens enough.
If that does not solve the problem here is what the TI Knowledge base has to say. Please read till the end. I hope it helps.
For the TI-83 Plus Family, TI-84 Plus Family:
Caution: The resets described in these troubleshooting steps will cause a loss of applications, programs and data. If at all possible please create a backup using TI Connect™ first.
  1. Try a new set of AAA batteries.
  2. Adjustthe contrast by pressing and releasing the [2nd] key followed by pressing and releasing the up arrow; repeat as necessary. To adjust or lighten the display, use the down arrow.
  3. Remove one of the AAA batteries. Press and hold the [CLEAR] key. While holding [CLEAR],reinsert the AAA battery and then turn the calculator on. The calculator should display the message "RAM Cleared". Release the [CLEAR] key and then press it one more time to remove the message.
  4. Remove one of the AAA batteries. Press and hold the [DEL] key. While holding [DEL], reinsert the AAA battery and then turn the calculator on. The calculator should display "Waiting...Please install calculator software now". Follow the instructions for the TI83-family or Ti84 Plus family to reinstall the calculator operating system (see below.)
  5. Remove all of the batteries including the round lithium battery for 5 minutes.After the 5 minute period, reinsert all of the batteries and turn the calculator on. Adjust the contrast if necessary.
Reinstalling the OS fot the TI84Plus
How do I correct the Error Waiting...Please Install Calculator SoftwareNow message on my TI-83 Plus family or TI-84 Plus family calculator?
If an operating system (OS) update fails or is interrupted, the calculator will be in an inoperable state with the message Waiting...Please install calculator software now.The most common cause of a transfer being interrupted is updating the operating system on a calculator with low batteries. Users will need to use the TI Connectivity cable and the TI Connect to send the operating system to the calculator. Make sure to have the latest version of TI Connect installed on the computer.
In order to install the software please follow these steps:
1. Connect the TI Connectivity cable between the computer and the calculator.
2. Click on Start >> Programs >> TI Tools >> TI Connect >> TI OSDownloader
3. Follow the on-screen directions to reinstall the calculator's OS.
If the message "Error! Press any key to turn unit off. Then turn unit back on." appears on the graphing calculator, quickly, remove one battery from the calculator and reinstall it while the transfer is taking place.
If that does not solve the problem, you should contact Texas Instruments at [email protected] or www.ti.com/calc.
3helpful
Every time I turn on the calculator, it gives me this message: Waiting... Please install operating system now after a while, the screen changes to: ERROR! Press any key to turn unit off. Then turn unit...
Read the following from the TI knowledge Base. Hope it helps
Turned on calculator and screen reads operating system not found install OS now
Here it is from the horse's mouth (TI Knowledge base). Please read till the end.
I hope it helps.
The batteries were all just replace including the lithium and it won't work I don't have cables with it does it need a download.
Usually, you should not change all batteries at one go.
It is likely that the calculator is ON, but the screen is too light to enable user to see anything. If that is the reason, you can darken the screen.
Press the [2nd] key and release it. Press and hold the UpArrow till screen darkens enough.
You can reistall the system (if needed) by connecting it to a working TI83Plus calculator. You need the calc-to-calc cable.
If that does not work, here is what the Texas Instruments Knowledge Base says about the calculator not turning on.
Without further delay, here it is from the horse's mouth (TI Knowledge base)
I hope it helps.
If an operating system (OS) update fails or is interrupted, the calculator will be in an inoperable state with the message Waiting...Please install calculator software now.The most common cause of a transfer being interrupted is updating the operating system on a calculator with low batteries. Users will need touse the TI Connectivity cable and the TI Connect to send the operating system to the calculator. Make sure to have the latest version of TI Connect installed on the computer.
2helpful
My TI-84 Plus Silver edition will not turn on. I have tried new batteries and everything, but it just does not turn on. Is there a way to reset it or something although the calculator does not turn on?
Caution: The resets described in these troubleshooting steps will cause a lossof applications, programs and data. If at all possible please create a backup using TI Connect™ first.
  2. Adjustthe contrast by pressing and releasing the [2nd] key followed bypressing and releasing the up arrow; repeat as necessary. To adjust orlighten the display, use the down arrow.
  3. Remove one of theAAA batteries. Press and hold the [CLEAR] key. While holding [CLEAR],reinsert the AAA battery and then turn the calculator on. Thecalculator should display the message "RAM Cleared". Release the [CLEAR] key and then press it one more time to remove the message.
  4. Removeone of the AAA batteries. Press and hold the [DEL] key. While holding[DEL], reinsert the AAA battery and then turn the calculator on. Thecalculator should display "Waiting...Please install calculator software now". Follow the instructions for the TI83-family or Ti84 Plus family to reinstall the calculator operating system (see below.)
  5. Removeall of the batteries including the round lithium battery for 5 minutes.After the 5 minute period, reinsert all of the batteries and turn thecalculator on. Adjust the contrast if necessary.
If an operating system (OS) update fails or is interrupted, the calculator will be in an inoperable state with the message Waiting...Please install calculator software now.The most common cause of a transfer being interrupted is updating theoperating system on a calculator with low batteries. Users will need touse the TI Connectivity cable and the TI Connect software to send theoperating system to the calculator. Make sure to have the latestversion of TI Connect installed on the computer.
Ifthe message "Error! Press any key to turn unit off. Then turn unit backon." appears on the graphing calculator, quickly, remove one batteryfrom the calculator and reinstall it while the transfer is taking place.
Hope it helps.
Wont turn on when new batteries were installed
I hope it helps.
2helpful
2answers
TI 84 won't turn on. New batteries installed. TI Connect recognizes device and I installed new OS. Brightness is not the issue. Any suggestions? This is one of student's calculators. Thank you.
Sorry, answer was posted as a clarification request.
  4. Removeone of the AAA batteries. Press and hold the [DEL] key. While holding[DEL], reinsert the AAA battery and then turn the calculator on. Thecalculator should display "Waiting...Please install calculator software now". Follow the instructions for the TI-83 family or TI-84 Plus family to reinstall the calculator operating system (see below.)
Hope it helps.
I changed the batteries and now it will not come on
Caution: The resets described in these troubleshooting steps will cause a lossof applications, programs and data. If at all possible please create backup using TI Connect™ first.
  4. Removeone of the AAA batteries. Press and hold the [DEL] key. While holding[DEL], reinsert the AAA battery and then turn the calculator on. Thecalculator should display "Waiting...Please install calculator software now". Follow the instructions for the TI83 or TI 84 Plus family to reinstall the calculator operating system (see below.)
Reinstalling the OS for the TI83/TI84 Plus family
If an operating system (OS) update fails or is interrupted, the calculator will be in an inoperable state with the message Waiting...Please install calculator software now.The most common cause of a transfer being interrupted is updating theoperating system on a calculator with low batteries. Users will need touse the TI Connectivity cable and the TI Connect software to send theoperating system to the calculator. Make sure to have the latestversion of TIConnect installed on the computer.
Hope it helps.
Replaced the batteries and downloaded the software
Hope it helps.
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Jerry Naidoo
Paul Bade
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
