The water-level switch regulates your washer's fill volume. This switch is usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. If the switch is defective, it may prematurely signal the water to shut off. If so, you probably need to replace the water-level switch.
Just out of curiosity did you fix problem? Mine is 15 months old never been used much (single person household) and it just started doing same thing. I have no water level setting it is an auto sensor (which I despise). Wondering if cost of repair is worth it since it cost less than $300. I've read other posts that had Maytag come fix and it still wasn't 100% fine. perhaps investing $ on new machine (different brand of course would be best).
Will that make it start agitating with no water In it
