You need to replace either the front bearing (plastic that drum rolls over) or the glides that go on the front bearing ( glides that insert into the plastic bearing piece that the drum glides on.I would change both, simply remove the top of the dryer then you will see two 5/16' bolts that hold the front to the sides just inside on the top, remove the two bolts and remove the front of the dryer and you will see the bearing and glides that I have described. Replace,reassemble and begin quiet drying again. Good luck!
the rear wheel bearing and drum is a single assembley this is removed by taking out 4 bolts fron behind the backing plate the drum and the wheel bearing can't be seperated and the cap over where the nut is should not be removed.
Hello Friend, This problem is real common in Hotpoint/GE dryers. Your solution is simple. You need to replace the front drum bearing and glider pads. It's actually pretty simple to do. Just remove front of dryer cabinet. After removal just look at backside of dryer front around the inner door. You will see where the dryer drum has turned and wore a hole in the plastic piece above the dryer door. This piece is called the front drum bearing. Just unsnap this piece and snap in a new one. Be sure to replace the little plastic glide pads onto the top of the drum bearing before re-installing the dryer cabinet front. The front drum bearing and glider pads are sold seperately so make sure you have everything you need before you begin. This should solve your problem. Happy to help, Tim. Thanks.
Hello Friend, This problem is real common in GE dryers. Your solution is simple. You need to replace the front drum bearing and glider pads. It's actually pretty simple to do. Just remove front of dryer cabinet. After removal just look at backside of dryer front around the inner door. You will see where the dryer drum has turned and wore a hole in the plastic piece above the dryer door. This piece is called the front drum bearing. Just unsnap this piece and snap in a new one. Be sure to replace the little plastic glide pads onto the top of the drum bearing before re-installing the dryer cabinet front. The front drum bearing and glider pads are sold seperately so make sure you have everything you need before you begin. This should solve your problem. Happy to help, Tim. Thanks.
Hello Friend, Your solution is simple. You need to replace the front drum bearing and glider pads. It's actually pretty simple to do. Just remove front of dryer cabinet. After removal just look at backside of dryer front around the inner door. You will see where the dryer drum has turned and wore a hole in the plastic piece above the dryer door. This piece is called the front drum bearing. Just unsnap this piece and snap in a new one. Be sure to replace the little plastic glide pads onto the top of the drum bearing before re-installing the dryer cabinet front. The front drum bearing and glider pads are sold seperately so make sure you have everything you need before you begin. This should solve your problem. Happy to help, Tim.
I recently replaced my bearings and seal for about $60. I could have bought the bearing cheaper online but I was in a hurry. If you do a search online there are several blogs about replacing these bearings. Here is a link for a service manual for $ 18 http://www.repairclinic.com/SSPartDetail.aspx?PartID=659075&PPStack=1 You pretty much have to disassemble the washer but it is not really that difficult depending on your mechanical experience. The manual should lay it all out for you. There are 2 notes on these frigidare washers: Sometimes the spider arms on the inner drum break and you will have to buy the complete inner drum assembly. I have heard they are warranted for 25 years, but they most likely will not warranty them if the owner does the work. Also, Frigidare does not list the bearings seperately, but you can buy the bearings from a bearing supply house, online or in your town. The bearing numbers are on the side of the old bearings when you remove them.
NOTE- The bearings that came out of mine were 6306-2Z and 6307-2Z (shielded) I replaced mine with 6306-2RS and 6307-2RS (sealed). The significance is that the shielded bearings offer minimal protection from water where the sealed bearings are built to seal out water/contaminants if you new seal ever fails. The seal I used was a CR15939 rubber coated seal.
If you need any other information, let me know
Hope this helps
