Have error 17h on konica minolta 2430 how do i fix it
Most likely you received this message after a toner was replaced. Reseat the cartridge and restart the printer. If that doesn't work remove all of the toner cartridges manually and reinstall.
Turn off the printer and open the top cover. Follow the toner cartridge all the way to the right side of the printer (on the white part). You should see a hole that looks like a cross. Take a pen or key and push down on the black button in that hole. While you are holding it down rotate the toner cartridge towards you. You want to get the colored roller on the cartridge about 1/2in away from the metal bar that says "consumable reorder". You should be in a position to take out the toner. Let go of the hole and remove the cartridge. Repeat the steps until all of the cartridges have been removed.
Turn the printer back on at this point. You are going to get toner not installed messages on the printer. Open the top cover and the cyan tray will be in place. Shake the toner and install. Close the cover and let it cycle to the next color (black). Repeat the process until all cartridges are installed.
If you are still getting the error you either have a bad cartridge or the carousel that the toners sit in is damaged.
• The Rack Positioning Sensor is in the blocked state
when the Rack Motor remains deenergized.
• The Rack Positioning Sensor is not blocked a second
time even after the lapse of a predetermined period of
time after it has been blocked once while the Rack
Motor remains energized.
• The Rack Positioning Sensor is unable to detect the
deceleration control position after the lapse of a given
period of time after the Rack Motor has started while
the Rack Motor is turning.
• The count value of the edge of ON signal of the Rack
Positioning Sensor during each developing positions
are not a predetermined value while the Rack Motor is
turning.
drum unit detection error on konica minolta
Konica Minolta error message stating they have insufficient memory when scanning
