Make sure you are getting power to both the red and yellow wires. red is ignition or switched power and yellow is constant power.
Testimonial: "thank you very much your answer was spot on thank you"
thankyou. pls can you also advise how to wire the red to ignition or switched power. does it connect to where the fuse box is or at the ignition barrel end. As ive also connected the red to constant to check if it works which it now does but this obviously keeps the system on at all times.
pls can you advise, thank you
you can connect it to the fuse box. if there is a fuse labeled radio, you should be able to connect it to that. it is usually a switched power source.
