Refrigerators Logo
Posted on Jan 18, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
It runs but the freezer and the refrigerator does not get cool
tom weber
Level 2:
  • Expert 198 Answers
  • Posted on Jan 18, 2011
tom weber
Expert
Level 2:
Answers
198
Questions
6
Helped
109560
Points
452
Check for frost in the freezer section. Might be problem with defrost cycle and or heater, or defrost bi metal
Anonymous
Level 3:
  • Master 321 Answers
Anonymous
Master
Level 3:
Answers
321
Questions
0
Helped
110681
Points
1111
If the freezer and the refrigerator does not get cold at all, then you need to check the refrigerators gas pressure level. If the gas is empty, then it will not get cold bot at the fridge and freezer level. I strongly advice you get the gas pressure or level checked and refilled to be able to get your freezer and refrigerator working fine once again. Hope this information was helpful. Thank you for using fixya.
3 Related Answers
Techsim
James
  • 59 Answers
  • Posted on Nov 02, 2008
SOURCE: Amana BX22A2W - freezer works, fridge not cooling
Check the damper in the top back of the fresh food section. make sure that it is open and air is coming through it.
Anonymous
  • 1902 Answers
  • Posted on May 20, 2009
SOURCE: The fan is running, but the refrigerator and freezer are not cooling. We cleaned the coils... any other suggestions?
Check the compressor and the relay. Make sure they are working when you turn on freezer and fridge to the max. If the compressor does not start then you need a new relay. If the compressor starts then it is your thermostat that has gone bad and must be replaced. you can find the parts on repairclinic.com and order them with instructions on how to remove the bad part and install the new part
Anonymous
  • 12 Answers
  • Posted on Aug 10, 2009
SOURCE: freezer and refrigerator stop cooling, back of
clean all the dust and form the gril on the back of your frig
The freezer leaks water constantly and runs out the front.
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Freezer works good but food side doesnt get cold and fan in freezer runs all the time
How to Defrost Refrigerator Defrost Timer Problem
heatman101
We have model 73912. The freezer is working and the refrigerator is running but not cooling. What might be the problem?
heatman101
Freezer too warm without change of previous setting; motor seems to be running ok.
heatman101
Refrigerator does not keep cold. Motor runs and freezer does freeze.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
heatman101
Fan in freezer runs and is cold. No air is coming
heatman101
My top freezer will not cool the motor is running but freezer stays hot ,the bottom is cooling ok
My guess would be that the defrost is sticking on...
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
heatman101
Freezer is working fine. The refrigerator is not
heatman101
1helpful
Refrigerator is not cooling, but the freezer is....
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
heatman101
q
Top Refrigerators Experts
ZJ Limited
ZJ Limited
john h
